Looking for discontinued MF 471-4 fuel line.
   / Looking for discontinued MF 471-4 fuel line. #1
S32
Boerne, Texas
2005 Massy Ferguson
It looks like the fuel line I need has been discontinued by Agco. However I now have a Agco part number. It is 6202205M91. A company called "Aftermarket Express" lists a aftermarket fuel line that is a replacement for that part number. But they have quite a few "bad" reviews. Has anyone done business with them recently, or can you recommend a good aftermarket replacement company?
   / Looking for discontinued MF 471-4 fuel line. #2
What's so important about that line that you can't work a way around replacing it?
  • Good Post
Reactions: JWR
   / Looking for discontinued MF 471-4 fuel line. #3
I used Aftermarket Express a few months ago and got the part I needed within a couple of days, no problems
   / Looking for discontinued MF 471-4 fuel line. #4
Are you not able to use hardline and bending/flaring tools?
  • Good Post
Reactions: JWR
   / Looking for discontinued MF 471-4 fuel line. #5
Yes, I agree. Most any auto mechanic shop is equipped to make and install whatever line like that you need unless you have to get one pre-made and prefer to install it yourself, etc.
   / Looking for discontinued MF 471-4 fuel line. #6
Same here with my MF563s.
Actually there are a number of parts that have been discontinued. Mine are only 2007 while I can still get parts for a Ford 8N and 9N which were 1940s 50s.
Went to a local automotive place and had a choice of regular or high pressure line. Bought it off the role.
It didn't come with the cloth weave on the outside but works just fine.
   / Looking for discontinued MF 471-4 fuel line. #7
It's just plain rubber line that slips over the nipple at each end. Only thing to make is cutting it to the right length.
They are rubber line with a cloth weave on the outside for protection. My pair of 563s use the same lines.
When I went to the local Massey dealer the parts guy, an idiot at the best of times, said they didn't stock fuel line.
The automotive place had no problem.
  • Good Post
Reactions: JWR
   / Looking for discontinued MF 471-4 fuel line. #9
It's just a rubber line.
At risk of nitpicking ...I know what you mean (and I often call it rubber line too) but I think it is really neoprene or anyway some material that will stand gasoline. Rubber air hose for example (actually rubber) would sort of dissolve in gasoline and contaminate the gas.
   / Looking for discontinued MF 471-4 fuel line. #10
Auto parts store sells fuel specific rubber-like substance line by the foot in high pressure and low pressure varieties
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2011 NORMAN POWER SYSTEMS 100KW GENERATOR (A52472)
2011 NORMAN POWER...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
