looking for detailed pics of window motor chute mods
   / looking for detailed pics of window motor chute mods #1
tractordog
Southern New Hampshire
T1520
Hi,
Looking for detailed pictures of your window motor chute mods.
It is time for me to think about it.
   / looking for detailed pics of window motor chute mods #2
Here is what I used. A jawtype coupling, power window motor from a 190E mercedes, and a piece of angle iron.
I have a electrical plug at the back of my tractor. I just plug in the connector and operate the motor with a two way switch. I don't need the blower that often but the few times I have used it it has worked great for me.
Thanks,
From the motors I have worked on it is not what I expected.
   / looking for detailed pics of window motor chute mods #4
Rather than a window regulator motor I used the little gear head motor that Surplus Center sells, it's a rather beafy little guy, and we made a diamond plate house for it to keep the snow off.
The process was: 1) remove the crank and shorten the drive tube, 2) mount a flex coupling, 3) make the mounting house to fit, 4) wire it up to a fused circuit (this motor will stall out at about 13 Amps) and 5) switch with a DPDT momentary in a convenient location.
DrMac
   / looking for detailed pics of window motor chute mods #5
Looks like you need a 'leaf' blower. ;)
   / looking for detailed pics of window motor chute mods #6
God and I made a deal. He makes the trees, causes them to grow leaves, brings on the fall season and lets the leaves settle beautifully to the ground, then I wait until He's finished and I blow them all away!
Bless you, brother.
DrMac
   / looking for detailed pics of window motor chute mods #7
DrMac
Very nice work. What actually turns the chute (from the coupling to the chute).
   / looking for detailed pics of window motor chute mods #8
Thanks, the turning mechanism is as built by Woods, cable wrapped around the drive tube and bolted to the base of the chute.
DrMac
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2008 DOOSAN G80 GENERATOR (A52472)
2008 DOOSAN G80...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
