looking for an older version of X738
   / looking for an older version of X738 #1
smote
john deere gt225
I sold my GT225 a couple years back and bought a zero turn. I miss having a rider for plowing snow and working around the yard. I went to the dealer to check out the 700 series. I like the X738 since it's 4x4 and I have some hills to climb when working in the yard. Since I don't want to spend the cash on a new I'd like to find one 5-8 years old.
What is the older model equivalent to the X738?
thanks
   / looking for an older version of X738 #2
Maybe the X585 or X595 would work for you. years 2002 - 2006
   / looking for an older version of X738 #4
X585 is the same set up but you can engage or disengage the 4 wd, so if you are turning sharp with the 4wd engaged in the grass, then the inside front wheel, when you turn, will mess the dirt, rock or grass up. On any x7xx series the front axle is hydraulic drive and is always engaged, but they have a valve hooked to the steering that changes the front wheel speeds when turning so it doesn't tear grass up. The x585, x7xx and x738 are all electronic fuel injected kawasakis and great smooth running mowers. The x595, x748, and x758 are all 3 cylinder yanmar diesels, still great running motors but the do have a little more vibration and noise at different throttle settings. I own an x585 and wish it was the x595 diesel I bought mine 7 hours ago and have been using a loader on it easy but working the tractor and have already put 13 gallon of gas in it. My old 455 was about 1.5 hours on a gallon of fuel. I'm sure the new diesels aren't quit as efficient but I have been working this new x585, it has 408 hours on it. Just my thoughts. I plow a lot of drives in the winter with mine and this will be the first winter, I am afraid I will have to fuel up before I am done. It's a small town with a gas station across town. So I don't know it I will need to carry fuel or if I will have plenty. I just ordered my 54 inch all plow from deere with the quick hitch and angle option and the setup was 1150 plus 100 for the lockout valve. That's with me installing it. I was pretty happy. That doesn't Include tax either, which is 6.25%.
Thanks for all the help with the older model names. I'll take a look at the machinefinder website to see what's available around my area.
   / looking for an older version of X738 #6
When cutting the same area with gas X739 or diesel 3320, the 3320 uses considerably less fuel. On the other hand, DW does not like diesel fumes and with my low use, I doubt the fuel savings would ever add up to the premium required for diesel. As mentioned the gas X7XX is probably quieter than diesel X7XX. With fuel injection it starts instantly.
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55302)
2022 John Deere...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
