Looking for an automatic battery charger without breaking the bank
   / Looking for an automatic battery charger without breaking the bank #21
1 Noco Genius G3500 and 1 SAE adapter on order :) It is a NEW YEAR and that means I have not purchased ANY battery charger yet this year...good to go! TMR
   / Looking for an automatic battery charger without breaking the bank #22
I have owned a battery tender jr. for years that I moved around to various equip I use in cold weather. Just got one of these Battery Tender 022-0185G-DL-WH Plus Battery Charger/Maintainer 12V @ 1.25A [BT-Plus] - $49.99
and hooked up a pigtail to my new tractor to make sure it fires up to move snow.
There is a charging bench in my garage that that off season batteries stay on and the charger just rotates from one to the next. Find they live a lot longer when you keep them charged up. Some things that I use in cooler weather get leads like this Battery Tender Harness | 350-110 | J&P Cycles
find them handy for hooking up heated gear to as well. Hope to stay comfy on my open station tractor blowing snow with my heated vest I use on the bike.
   / Looking for an automatic battery charger without breaking the bank #23
Yep, thats how I do it with the noco, the snowmobile batteries rotate out to tahe lawn tractor and bikes for winter in my garage.
   / Looking for an automatic battery charger without breaking the bank #24
I have a pro mariner 300.
Little expensive but water proof and will charge a bank of batteries at once.
... Features
Professional Grade Series On-Board Marine Battery Charger
Distributed-On-Demand™ Charging
Automatically senses and distributes a full 10, 15, 20 or 30 amps
(model specific) to any one bank or combination of all banks.
Faster Charging
2 to 3 times faster than traditional battery chargers, with true 3 step charging technology
each step is electronically controlled for the fastest charge.
Professional Performance
100% battery charge guaranteed.
100% charging output with AC power as low as 90 VAC while using long extension cords at the dock, lodging site or home.
Proven to condition and
extend the life of your batteries.
Compact Lightweight Design
Rugged “Space Saver” all aluminum housing is half the height and weight of leading traditional chargers.
Unit is not potted and is completely serviceable for a lifetime of use under ProMariner’s lifetime repair guarantee.
Built-in Safety
Reverse polarity, ignition and over temperature protection.
Easy Operation
Pre-wired for easy installation.
ProTournament Series | ProMariner
   / Looking for an automatic battery charger without breaking the bank #26
I have 3 of the Battery Tenders you linked and 1 Junior. One dedicated to the tractor, one dedicated to a built Jeep, and one that floats around. The Junior is on the Zero Turn. I have a Quick Connect harness on most of the vehicles mounted outside. Makes it simple and quick to connect and disconnect. Can't beat the price.
   / Looking for an automatic battery charger without breaking the bank #27
I have used several brands of battery maintainers including the Battery Tender all good. But I recently purchased 4 of the Yuasa brand 1amp charger/maintainer from Amazon for $30 each. After a little research on these units I thought this were better and more advanced then the Battery Tenders units I have used in the past. Only time will tell.
   / Looking for an automatic battery charger without breaking the bank #28
I have Schummacher model SE 1275a that I purchased in November of 09. It is a 2-12-75 amp machine and it has served me well. I bought it for sixty bucks then. Worth every penny.
   / Looking for an automatic battery charger without breaking the bank #29
   / Looking for an automatic battery charger without breaking the bank #30
I have a couple or three of these Battery Tender Plus...
Amazon.com: Deltran Battery Tender (021-0128) 1.25 Amp Battery Charger: Automotive
In Costco today and saw a new one...
Battery Tender Power Plus 3 Amp Charger
Looks like the difference is 1.25amp vs. 3amp for the new one. Both maintainers. The new one is sleeker and half the weight if that matters. I am sort of old school with the bench mounting but the new one suits 'in line' installation and it's a few bucks less.
Says it is waterproof and cycles between 80% and charged...
Price is good...
I had one of my other charger out hooked up to the truck semi protected and it rained... the label started to come off.
Don't own any waterproof/resistant chargers yet.
JOHN DEERE 4440 TRACTOR (A54756)
JOHN DEERE 4440...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
MISC TIRES (A54756)
MISC TIRES (A54756)
TRACKLESS MT5TD SERIES V TRACTOR (A51406)
TRACKLESS MT5TD...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
