3-Point Hitch Looking for adjustable link for 3pt hitch on 790
   / Looking for adjustable link for 3pt hitch on 790 #11
As Captain Chaos would say: DA-DA-DUM!
The adjustable side link that dirt ditch has on the right side of his 3pt hitch is what I want. I'm thinking now maybe I could just weld some 3" long pieces of 3/8" round steel stock opposite of each other on the center link to adjust it with?
   / Looking for adjustable link for 3pt hitch on 790 #13
I still have to get off the tractor to loosen the lock nuts on the center link and the side link. I use the rubber mallet in the pic to tighten and loosen the center link locking nut. Can't tighten it enough by hand that it won't lengthen with weight on the 3 point.
   / Looking for adjustable link for 3pt hitch on 790 #14
To be honest, I can't remember for certain how my side links attach at the top, and the tractor is about 60 miles from me. Maybe someone else here who has a 790 can look at theirs and tell us?? I do know that the adjustable sidelink needs to be about 19inches long for the attachment to sit level before doing any adjusting.
If the one you have will fit my 790, I may be interested in buying it from you if you decide to let it go.
This link should help identify the parts on your JD.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet
Just type in your model number in the box at the top left and click on the 'find'...pick out your tractor in the search results.
   / Looking for adjustable link for 3pt hitch on 790 #15
Kebo.....are you certain that you do not already have an adjustable link on the right side of your 3 point? :confused: I think this is pretty much a standard feature. You and I have about the same tractor (if my memory serves) and mine has the screw adjustable link on the right. Granted, there are no "wings" to crank on it (I use a big crecent wrench on the flats provided) but I have adjusted my box blade to crown a road with that link on mine. I think you need to have another look.....no? :confused:
You could easily add "wings" to the existing adjustment screw which would make a big improvement IMO.....but it does work o.k. as is.
   / Looking for adjustable link for 3pt hitch on 790 #16
The turning handles on the 3x20 series look to be a bit more refined and easier to turn when there is weight on the 3pt.
Yep, it has the adjustable link on the right side.... only you have to loosen the jam nuts on either end before you can adjust it, then retighten them once you adjust it. I want one that has a crank handle (preferably) but if I can't find one like that, then I'll settle for one like dirt ditch has on the right side of his 3pt hitch. Makes it quicker and easier to adjust.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
iDrive TDS-2010H...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
