looking for a used/rebuilt yanmar for 950JD
   / looking for a used/rebuilt yanmar for 950JD #1
jbfishman
I have a 1987 950 JD with a bad block. The engine tag is missing, I believe it is 27hp at 2600, 3 cyl, non-turbo. I have been told it may be a 3T90J or a
3TNE88 I don't know which with the motor ID tag missing but I need a good runner or rebulit one. The current engine has all good trim so even a short block would work. Any help on sourcing or even the correct motor model info would be greatly appreciated.
   / looking for a used/rebuilt yanmar for 950JD #2
I'm getting in a JD950 parts tractor that was damaged in a fire. The firemen kept water on it, so it wasn't hurt bad in the fire. I'll have to check the condition of the engine.
Thanks for the response. I will be on the standby to hear what you determine. You can also email me at jbates@peak.org
Jerry
Just checking to see if you have rec'd the JD950 yet.
Jerry
   / looking for a used/rebuilt yanmar for 950JD #5
It turns over by hand. Tires are still up. I want to get it started before I quote any prices.
Just checking to see if you have had time to check out the used 950 motor yet.
Jerry
   / looking for a used/rebuilt yanmar for 950JD #7
The engine model is imprinted into the casting on the lower left side
of the block usually. Not just on the valve cover.
You will likely have to use one from another 850 or 950 so you get
the correct bellhousing and oilpan shape and mounting points.
   / looking for a used/rebuilt yanmar for 950JD #8
Have you checked with Fredricks Equipment in Hartsville, Al. They advertise repairs to cracked blocks and etc. Good people to deal with.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55218)
2018 John Deere...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR Crane Service Truck (A52377)
2019 Chevrolet...
