Looking for a tractor 40-60 HP.
   / Looking for a tractor 40-60 HP. #11
Give Massey Ferguson a look.
We’ve had 2 or 3 other threads recently where a tractor shopper was leaning Kubota, but went with Massey instead. They found the MF to be much heavier duty and heavier in weight, too. Weight is power and stability that makes your tractor more useful & versatile.
   / Looking for a tractor 40-60 HP. #12
The MX is not a compact tractor. It is a light duty utility tractor that can run Cat. 2 implements. No it’s not in the M series class, but neither is it in the L, LX, or B series compact class.
could well be true. difficult to say as one jumps from one category to another in Kubota models... then there's the Grand L series too boot
My point is that one should carefully study the models before jumping into the next model. this forum s filled with "wish i had gone..."
believe me, i made mistakes myself before my final trade in to my current model tractor that meets my needs perfectly, best regards
   / Looking for a tractor 40-60 HP. #13
Very true. I know Kubota lists the MX as a utility tractor, but of course it’s not as heavy or capable as the larger M models.
   / Looking for a tractor 40-60 HP. #14
it's amazing just how many models/options mostly non commercial users as ourselves have on the market today. compared to the old days when i had the ol' Massey TO35
learned the hard & expensive way, it pays to do the the homework to make the right choice. & try not go get into the purchase fever along the way, best regards
   / Looking for a tractor 40-60 HP. #15
LS makes CUTs for NH and Case. They do not make the utility tractors, such as the Workmaster 50-60-70 series and Workmaster 55-65-75 series. While LS makes the tractor, it is sold and serviced by NH or Case. NH and Case dealers are usually pretty stable and well stocked with parts. Parts for the most part are the same, just a slightly different part number. NH does use their own loaders.
   / Looking for a tractor 40-60 HP. #16
My Kubota dealer told me the MX has a heavier differential, axles etc. than the grand. In any case I'm real happy with the MX5200 as an all around utility tractor for dirt moving, mowing, and road maintenance.
   / Looking for a tractor 40-60 HP. #17
For the year range of my 2005 Kubota Grand L5030 ... The Kubota MX5000 is very close in dimensions, and capabilities ... Current late models may be different ... All data taken from "Tractor Data. Com
Kubota L5030 vs MX5000
Both have same basic engine.
Standard tires (ag)
L5030 Front: 9.5-16. Rear: 14.9-26
MX5000 Front: 9.5-16. Rear: 14.9-26
Dimensions L5030 - MX5000
Wheelbase 75.4”. - 71.1”
Length 126.2”. - 132.5”
Width 67.3” - 62.4”
Height (ROPS) 92.7” - 84.8”
Height (cab) 89.4 inches - (MX not available)
Ground clearance 15.9” - 15.2”
Front tread 52.8". - 52.2”
Rear tread 52.2"/56.3" - 54.1"/58.7"
Weight
ROPS Shipping 3705 lbs. - 3,560 lbs
Cab Shipping 4090 lbs
ROPS Operating 3,800 lbs
The L5030 has an optional mid PTO, while it has less loader lift capacity, it has a higher lift capability, and a cab.
   / Looking for a tractor 40-60 HP. #18
I've been looking at compacts in the HP range that the OP mentions and the 2860M (2m.60) power shuttle would be a great option- Made in Japan by Iseki, known for quality manufacture. Also maybe a YT359 by Yanmar, also made in japan by a high quality manufacturer - issue here is likely to be presence of a good dealer. Both slip in the middle between Kubota and Kioti price wise but are capable and have a great feature assortment.
For a small utility a MF 4707 would be a great choice
   / Looking for a tractor 40-60 HP. #19
Kubota verse Kioti videos show Kubota hydraulics to be superior to Kioti hydraulics. Mostly on loader operations.
   / Looking for a tractor 40-60 HP. #20
I have an NS6010, previously had NX6010, got both as left over inventory at a very good price. The Deadong diesel is pretty much bullet proof IMO - zero issues with either tractor. NX vs NS are very similar, but I preferred the NX cockpit vs the NS, which is just a littler bit smaller and only has entry step on one side. I prefer the NS loader controls vs the NX which were had a problematic joystick actuator which I replaced 2x in 400 hours. It was an easy fix, and the part was $120, but still a PITA. Kioti has a good warranty, but dealer is a big factor - I have dealt with 3 kioti dealers, two were great one was a shyster.
CASE CX160 (A55272)
CASE CX160 (A55272)
FUEL PUMP & HOSE REEL (A52708)
FUEL PUMP & HOSE...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
