Box Scraper Looking for a stout inexpensive Box Scraper
   / Looking for a stout inexpensive Box Scraper #1
a4jock
Lookinf to buy a 66" box scraper. Don't want to spend a fortune. I live in AZ where the ground is pretty tough.
Any suggestions, especially welded vs bolt on A Frame, main frame size, etc.
   / Looking for a stout inexpensive Box Scraper #2
I bought my 60" box blade brand new for $199 at Tractor Supply.
This link shows some pictures of the blade and explains more details on what I found available. I hope this helps. I couldn't find a used one for any where near the same price as the new one I bought. It has 2 reversable cutting blades on it.
http://www.tractorbynet.com/forums/attachments/152596-will-box-blade-help-2.html#post1758754
This link is to an extremely tough looking box blade I found on our local craigs list. It is a Hesston brand.
Rake, Box Blade, Aerator, and Brush Hog
   / Looking for a stout inexpensive Box Scraper #3
IMO, those 2 words Stout & Inexpensive can't be used together....Take your pic of one or the other...
IMO, I'm all done with TSC impelements...except for maybe the KKII Tiller, that unit seems to get rave reviews here...I'm not joking when I say the time stamp from the PURCHASE Reciept of a TSC Landcape Rake and the RETURN Reciept was less then 2 hours... I didnt abuse it, and she was twisted like a pretzel...
   / Looking for a stout inexpensive Box Scraper #4
I dunno... the box blade that I bought was identical to the King Kutter next to it except for the color. The diference in price was $350...$200 vrs $550
I think I need a bigger tractor because I have been unable to damage this one no matter how hard I try.
I have seen some TSC implements that looked a little weak. When I picked up my box blade they had a 6 foot disk that had a twisted angle iron frame that had been returned. It was clear that the previous owner had backed up with the disk in the ground and the frame wasn't up to that task. I asked if they wanted to sell it but they said they could not, it had to be returned to the manufacturer.
I would have just hammered it straight and not used it in reverse.
The ones with the tube steel frames are much more rigid.
   / Looking for a stout inexpensive Box Scraper #5
I've had my Gannon for over 10 years now and it's been REALLY used. I do finish grading and hydroseeding so it's not been babied. I had a cheapie from one of the local tractor places first and it was way too flimsy and lightweight for what I needed. I use mine on the rear of a 52hp Ford tractor with 6 way hydraulics and it'll surprise you what all it will do with some practice. If you can add the 6 way hydraulics to your tractor it'll make that box blade a 1000 times better to use and operate.
The Gannon is a lot heavier built which helps with cutting and also when prying out small trees :)) it really works great although not designed for it) with the corner and using the hyd tilt to pry it out of the ground with some rearward pressure. One of th every best attachments for maintaining a driveway and ditches cleaned out. Back when I got mine local builders laughed when I'd pull up with that and they expected to see a dozer or skid loader to move the dirt around a house but they didn't laugh for too long when in a couple hours I was filling up the hydroseeder.
Money well spent if you plan on using it a lot and don't want to keep repairing it.
Topstrap
   / Looking for a stout inexpensive Box Scraper #6
Topstrap
The Heston I found on craigs list looked like a beast. It was only $650
I don't have an excuse to own anything like that because my little tractor doesn't have enough power to hurt the one I have. I am constantly amazed at the amount of material I can move with it.
   / Looking for a stout inexpensive Box Scraper #7
I would not call anything King Kutter stout. I have torn up plenty of their stuff. If you want a stout anything look for captured pins, welded gussets, ect.
You get what you pay for. I bought a King Kutter mower and it lasted 3 years and I had to put over $800 in parts on a $1200 mower. Bought a Caroni and have only replaced 1 $1 bolt that fell out. Same thing with my 6' Howse rear blade. Broke it in half 2 times. Bought a 7' Woods to replace it and not one issue.
Chris
   / Looking for a stout inexpensive Box Scraper #8
Bought a United 6'. Its a welded A frame. Paid $500 new off the lot with a little rust. Have beat the tar out of it 2 of the 4 times I have used it so far with no ill effects. Stoped the tractor in 4x4 with it more than a few times:D.
Forgot to add the 4 times it was used was with scarifiers all the way down. Clay, roots, small stumps.
   / Looking for a stout inexpensive Box Scraper #9
Chris
the only actual King Kutter implement I have is my dirt scoop. I bought it used so I don't know how much it had been abused previously, but the pins are a little bent out of shape but I haven't nmanaged to hurt it much. I have only moved about 100 cubic yards of dirt and asphalt with it.
   / Looking for a stout inexpensive Box Scraper #10
Topstrap
I have a Frontier BB1284 with all hydraulics and is very similar to the Gannon. I agree they don't get much better than that. I also have made a landplane 96" wide with 60" skids (about 950 lbs) that I use to finish off grades with, works great.
Steve
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
2025 AGT MX15RX Mini-Excavator with Dozer Blade (New/Unused) (A59225)
2025 AGT MX15RX...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
UNUSED FUTURE 13" MINI GRAPPLE (A58376)
UNUSED FUTURE 13"...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
68" ROTARY TILLER (A58375)
68" ROTARY TILLER...
