Looking for a snow blower pulley
   / Looking for a snow blower pulley #1
Rio_Grande
Platinum Member
I am repowering a older snowblower that had a tecumpshe 8 horse on it. When I measured the shaft I aparently measured over top of a bushing and my new motor has a 1" shaft and should have had a 3/4 shaft. I have everything else worked out on the unit but I cannot find pulleys for it. Actually what I need is 1 in ID x 2 in od and 1 in id x 3 in od Or a gang pulley to cover the auger and drive pulleys on the main shaft. I have looked at granger, Mcmaster Carr, Pheonix mfg, ebay and no luck.
the 3 inch is obtainable but I dont want to buy it and find out I can only get the 2in in a gang pulley than be out the dough and time.
Any assistance direction or combonation of the two would be appriciated.
   / Looking for a snow blower pulley #2
Call some alternator shops.
   / Looking for a snow blower pulley #3
I've researched several pully's here Ag Supply - Roller Chain, PTO Shafts, Hitch Pins, Cab Cams, Sprockets, Set Collars, Top Links, Bearings, Pulley
Early this spring i needed a pulley for a quite unusual 1 3/8 10 spline shaft, After much looking and research i found Triple R Inc of Primghar, IA I called these guys and talked to Robert. In less than half a day he'd located a splined bushing, hub and pulley combination for me and they did all the necessary machine work on the parts so it was ready to weld together after alignment on the mower.
For common sizes you may well also find hub and weld on pulley combinations to suit your needs at a bearing supply.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2019 Freightliner M2 106 Flatbed Hauler Truck (A55973)
2019 Freightliner...
2017 Kubota M7-151 Premium MFWD Tractor (A56435)
2017 Kubota M7-151...
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
