Looking for a snow blower pulley
   / Looking for a snow blower pulley #1
Rio_Grande
Platinum Member
I am repowering a older snowblower that had a tecumpshe 8 horse on it. When I measured the shaft I aparently measured over top of a bushing and my new motor has a 1" shaft and should have had a 3/4 shaft. I have everything else worked out on the unit but I cannot find pulleys for it. Actually what I need is 1 in ID x 2 in od and 1 in id x 3 in od Or a gang pulley to cover the auger and drive pulleys on the main shaft. I have looked at granger, Mcmaster Carr, Pheonix mfg, ebay and no luck.
the 3 inch is obtainable but I dont want to buy it and find out I can only get the 2in in a gang pulley than be out the dough and time.
Any assistance direction or combonation of the two would be appriciated.
   / Looking for a snow blower pulley #2
Call some alternator shops.
   / Looking for a snow blower pulley #3
I've researched several pully's here Ag Supply - Roller Chain, PTO Shafts, Hitch Pins, Cab Cams, Sprockets, Set Collars, Top Links, Bearings, Pulley
Early this spring i needed a pulley for a quite unusual 1 3/8 10 spline shaft, After much looking and research i found Triple R Inc of Primghar, IA I called these guys and talked to Robert. In less than half a day he'd located a splined bushing, hub and pulley combination for me and they did all the necessary machine work on the parts so it was ready to weld together after alignment on the mower.
For common sizes you may well also find hub and weld on pulley combinations to suit your needs at a bearing supply.
2024 Polaris General XP 1000 Premium  (A52384)
2024 Polaris...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
1065 (A53342)
1065 (A53342)
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
Top Hat Bumper Pull Trailer (A53117)
Top Hat Bumper...
2009 Ford F-350 4x4 Flatbed Truck (A51691)
2009 Ford F-350...
