Looking for A New Starter for 336D.
   / Looking for A New Starter for 336D. #1
Rameck
So.Ca./Mossyrock,Wa.
Yanmar 336D
Part # is 124250-77012 Type S12-77. Contacted Hoye and it $356 shipped. Has anyone replaced theirs with a different starter that works without the high cost? Rebuilder I talked to wants around $200 and that's if it can be rebuilt. Found one that says it replaces the part number but it much different looking and bigger, so don't know if it would actually fit. Never saw what Hoyes looks like.
thanks,
Ralph
   / Looking for A New Starter for 336D. #2
   / Looking for A New Starter for 336D. #3
   / Looking for A New Starter for 336D. #4
I replaced my YM240/YM2000 starter with a higher-output one at very reasonable cost. 2KW, 15 tooth. It sure looks like the 336D replacement that Barry referenced for you.
I described it in a couple of posts in this old thread. The second post has a picture of the replacement alongside the (wrong) 'rebuilt' starter that was on the tractor when I bought it. There was plenty of space for the extra quarter inch length of the more powerful starter.
YM1700 won't start - Page 3
All suggestions heading the right way but falling just short of what I need. The YM240/YM2000 and YM1700 starters have the wrong oem number for cross reference, so they won't work. 15 tooth and 1.5 KW is what the original specs call for, though a higher KW is OK. The starters I've seen match the oem part number don't look exactly the same as mine. They look like the one California used. They have a plug to connect the starter cable too and I don't have a plug to fit into the connector (California, how did you connect yours up?). The picture from Hoye does match the same type I have but I don't use the tractor enough to justify the higher cost. If I don't find one that looks like mine physically, I may try the other style.
Barry1, "Small Engine Part..." doesn't have my oem reference listed, so, I guess they don't have my starter either.
   / Looking for A New Starter for 336D. #7
in the pic here New Starter CTS1277 it shows a stud on the side of the starter where the cable connects . I don't see the connector you speak of
   / Looking for A New Starter for 336D. #8
Whats wrong with the Org. Starter? I just checked a old Receipt from when I had my 2000 starter done on 5/2011. The motor was worn slap out on it!! The shop even mentioned it when they seen the Brushes was Rev. I done that Yrs. before and it was only 72.75$ to rebuild it :cool:
   / Looking for A New Starter for 336D. #9
Here's a photo of what I installed.
The wire from the keyswitch goes to the screw connector above the battery terminal. This isn't ideal design. Its too easy to hit that solenoid terminal with a jumper cable and crank unexpectedly. There should be a rubber shield there. I wrapped mine with electrician's tape.
When I bought my Yanmar it already had a badly-rebuilt starter of this style. (and no protection on that terminal). The wire from the keyswitch had been cut and a 6 inch extension added, because the original starter had its similar terminal on top.
Aside from this awkward terminal I think this starter is a broad-application replacement across many Yanmar and Deere models. Its beefy 2kw cranking power should raise the dead (equipment). :D You noted you are replacing a 1.5 kw starter, my application called for 1.2~1.4kw. The tractor cranks like crazy and fires instantly. Via Ebay this cost $100, shipping included.
Specs from Rareelectrical website
YANMAR 171353-77010
NIPPONDENSO 128000-2070
JOHN DEERE AT110818
OEM(s): Denso, John Deere, Yanmar
Type: OSGR
Voltage: 12 Volts
kW: 2 kW
Rotation: CW
Teeth/Splines: 15 Teeth/Splines
Pinion/Splines OD: 44mm / 1.732in
Mounting Hole 1: 13mm ID
Unthreaded
Mounting Hole 2: 13mm ID
Unthreaded
New or Remanufactured: New
Approximate Weight: 12.1 lbs / 5.50 kg
   / Looking for A New Starter for 336D. #10
Looks like the exact starter for less $$. When I need a starter I know where I'm going to buy it
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
