Looking for a new 38-44HP Tractor
   / Looking for a new 38-44HP Tractor #11
Lots and lots of good choices for those uses. I would recommend HST for the hills, mowing, tilling, and FEL work. Best bang for the buck might be the Kioti DK45SE HST, a model that's been around for only a year or so. 45 engine hp, around 38 PTO hp, and something like $23k with HST and FEL (4wd is standard). There are of course choices from virtually every maker, especially Kubota and JD. The JD 4x20 tractors are really nice but battle with Kubota to be the priciest CUTs in existence.
   / Looking for a new 38-44HP Tractor #12
I think you will love the JD 4x20 series. 44 HP seems too small for 75 acres, though.
   / Looking for a new 38-44HP Tractor #13
Lee77 said:
Thanks for replies, like to hear more about Kioti DK40se VS Mahindra 4110 or4530 Thanks again.
Well, I cannot compare the Kioti to the Mahindra as I only have the Kioti but can give you my impression of the 40se. I've only got 20hrs on it so far and I have the HST version with the matching KL401 loader. Also, in case you are looking at slightly more HP, I believe the only difference between what I have and the DK45se is about 4 horsepower and almost $2000.
I am very impressed with the tractor so far. It is a more sophisticated machine than a basic tractor and has goodies like electric PTO, electric 4wd selection, suspension seat, tilt wheel, standard rear remote (one set) etc. I am very impressed with the loader which has 2700lb lift capacity at pivot points. So far I have mostly been either "bush hogging" with a six foot Caroni flail mower or ripping up bushes/trees with a grapple on the FEL. Works like a charm with both those applications. Haven't done any ground engaging work yet. The tractor with FEL must weigh close to 5000lbs. I did not load the rear tires as I was a bit concerned about too much weight on the 100year old wood barn floor where I store it but if that were not an issue I'd load the tires. With R4s even in 4wd and with a 600lb mower I can easily spin the tires in dry conditions on turf or dirt while pushing something with the grapple.
The overall fit and finish on the tractor is excellent. All the service points are readily accessible. Haven't had to change oils yet but both engine and hydraulic oil levels can be easily checked without kneeling. I've been mowing in high seedy grasses and have had to clean the radiator prescreen a couple of times. That is pretty conveniently set up too.
The seat and operator station are very comfortable. Seat is suspension and height adjustable. Controls are very well placed and easily monitored via warning/operation lights on the dash. I like the electric four wheel drive selection and PTO. No clutch on this tractor which took a little getting used to but I find no real downside to the electric PTO so long as you lower RPMs to about 1000 before engaging it. I did that with my previous clutch tractor anyway so really it's just a matter of getting used to not having a clutch. Flipping a switch for 4wd is great. One unexpected bonus with this tractor is how manuverable it is. I am very impressed with the turning radius which is under 10 feet and very close to my much smaller CK20. The 3PT set up is very flexible and has one telescopic arm as well as extendable pin arms on both sides. It also has a very nice solid adjustable stabilizers for the 3pt arms rather than chain stabilizers. The chain type are always coming loose or require wrenches to adjust. The new system on the DK series just requires dropping a pin into a hole once you adjust them with a simple pull.
My only complaints so far are pretty minor and some just reflect the disadvantages of a big vs compact tractor. With my smaller CK20 I could easily see over the hood and monitor precisely where I was putting the grapple. With the DK40 I cannot see the ground where the grapple touches unless I lean outboard and peek around. I think if I had to do it over I'd probably load the rear tires with RimGuard as I had on my smaller tractor. Maybe that would not be necessary with R1s. The KL401 comes standard with a quick attach system that is technically "universal" in that you can mount universal skid steer implements. However, it is for some inexpicable reason about 4 inches narrower than a typical skid steer QA so while you can mount standard skid steer attachments, there is about 2 inches "play" on either side. That doesn't interfer with attaching the implement but means that the implement can, with side pressure, slide on the mount once attached. It is only an annoyance but does mean that you have to pay more attention than necessary in lining up the QA to get it centered (normally you just look at one side and if it fits you are good to go, with the Kioti narrow QA you need to insure that you have it centered by looking both right and left as you line up...not hard but a pain) Also, if the implement does slide during use you need to detach the implement and line up again to recenter. I cannot understand why Kioti chose to use a narrow QA as there is no advantage. Only service issue I have had is a poorly designed seat belt retractor that came apart at about 10hrs. Waiting for a replacement (hopefully a redesigned one).
Overall I am very impressed with the DK40se HST and KL401. I chose it over the comparable JD and Kubota models based on price/value mostly but also for the loader which signifcantly more lift and breakout capacity than the JD300Cx or the Kubota LA853. I also had been very pleased with the performance and reliability of my Kioti CK20 so it was a pretty easy decision especially once I compared prices. 4 year warranty also helped. The dealer (Wallace) made the decision even easier by agreeing to deliver to my remote island location and gave a very fair trade in on my CK20 TLB sight unseen.
   / Looking for a new 38-44HP Tractor #14
The new holland TC line is, in my opinion, very good. I think the TC40 w/o cab is in your price range. If you go to the NH forumn, you will see some discussion on TC40 pricing. The TC45, is about 1500 more(I think).
Chris
   / Looking for a new 38-44HP Tractor #15
The 4530 is a utility size machine, the 4110 is a large compact. I think if you step up to a utility, go with a 5500 or 5520, or 5530. In my opinion, they offer a lot more performance for not that much more $$ than the 4530.
Don't forget the 4720 Branson. If has the Cummins A2300 engine, is nice and heavy and has a 4 year warranty. Shuttle shift, etc.
   / Looking for a new 38-44HP Tractor #16
The JD 990 will get you about 40 hp and keep you in the JD family (although the engine is a Yanmar.) I have a Kubota L4400 which is the most bang for the buck you can get in a 45 hp tractor as far as I am concerned, and it does fine on my 250 acres. But it is a light tractor and most of my 250 acres is woods. I've have mowed 20 plus acres with it using a 6 foot rotary cutter, but it took the better part of a workday to do it.
If your 20 acres that needs to be mowed is one large or several large spaces, something that could pull an 8 to 10 foot mower would be better. If it is lots of smaller spaces, then a 45 hp tractor, a six or seven foot mower and a fair amount of time will serve you well.
My L4400, with 4wd and FEL and rear remotes cost about $19,000 two years ago.
My property is hilly as well. No problems. HST might be nice but if can think ahead a tiny bit, gear drive is not an issue.
   / Looking for a new 38-44HP Tractor #17
N80 said:
The JD 990 will get you about 40 hp and keep you in the JD family (although the engine is a Yanmar.) ....
A minor point of clarification, the 990 is built entirely by Yanmar, not just the engine. Not a bad thing, they are well made machines.
   / Looking for a new 38-44HP Tractor #18
I'm not disagreeing, but the JD dealer told me it was just the engine. Truth is, I would have been happier to know that the the whole thing was made by one manufacturer. I've never been fond of things made by too many parties and I have no problem with Yanmar.
   / Looking for a new 38-44HP Tractor #19
The 990 is a rebadged Yanmar, and it is also a lightweight.
   / Looking for a new 38-44HP Tractor #20
Lee77 said:
Hi, thanks for any help I can receive.
I have 75 very hilly acres and I'd like a tractor that has the strongest, heaviest frame in this class. When looking at brochures, everyone seems to weigh their tractor a different way. Kubota's seem to be on the light side and Montana's seem to be low and wide which would be good for my hills but some of the persons in your groups have had bad experiences and say, "stay away" (only 5 years old). I'm upgrading from a 20yr old JD-850 that's been unbelievably reliable. I'm not very mechanically inclined and I'd like to keep that reliability and stay out of the dealer's garage.
Thanks again for any help.
I live on a very hilly farm in Appalachia, Eastern KY. We have some very steep hills and I can tell you that some of the compact tractors are way too light for hilly terrain. When I went shopping for a tractor in the same range I found the MF 1540, JD 990, the various Kubotas, the NH TC 40, and the Montana all to be much lighter than the Mahindra 4110. Those machines would scoot on gravel on the dealers' lots during test drives, but the Mahindra 4110 didn't. If they are going to scoot on flat gravel lots I certainly cannot trust them to stop on steep Eastern KY hillsides.
The Mahindra 4110 is the heaviest compact I looked at, and it shows when stopping on a hill or doing grunt work on the farm. The 4110 weighs in at 3969 lbs. By the time I loaded the tires and added the FEL the little red beast was pushing 6K.
I paid $19,300 for my 4110 in May '05, and they aren't much higher now. They feature a 12X12 shuttle tranny, and a sweet running Daedong diesel.
I have just over 200 hours on my Mahindra right now, and she has performed very well for me without any problems.
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2002 INTERNATIONAL 4700 4X2 SEWAGE TANK TRUCK (A51243)
2002 INTERNATIONAL...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
(INOP) 2014 DEERE 210G LC EXCAVATOR (A51242)
(INOP) 2014 DEERE...
