looking for a measurement on a jd 430 fel
   / looking for a measurement on a jd 430 fel #1
ebeb
Bronze Member
Akron, Ohio
JD 4410
need to know size of opening, how far from top of top lip to ground, how far from that spot to end of bottom lip
buying a grapple that attaches to the fel, need to know how long it needs to be to make it to the bottom of the fel
quickly if you can!
eric
   / looking for a measurement on a jd 430 fel #2
Need to ask what bucket you have?
There is a "hd" after your 430 FEL, and I am wondering if that is for the 61" heavy duty materials bucket? If so, I can measure mine. If not, someone else will have to help if they can.
So, just in case you have the HD 61" bucket, The height to the top is 17.75" (coming square up from the buckets' flat bottom) and the tip to the top is 21"
thanks
mine is the 430 heavy duty 71" bucket (opening is the same as what you have)
thanks again!
Eric
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2020 Chevy Silverado (A56438)
2020 Chevy...
Spartan RT-HD Zero Turn Mower (A59814)
Spartan RT-HD Zero...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
