Backhoe Looking for a little advice on backhoe mounting
   / Looking for a little advice on backhoe mounting #11
Maybe there are different types of "subframe" setups ...
Given he number of manufacturers, that probably goes without saying ... ;)
but the ones I'm familiar with do not use the 3 pt attachment points in any way. Here's an image of the left side mounting points for my backhoe; the right side is the same. The subframe extends underneath the tractor as shown in the second photo.
Yup ...
As stated by zmansmac the frame support kit - or "subframe" - on the Kubota essentially reinforces the connection between the engine/frame/transmission.
I don't believe that zmansmac or anyone has claimed that the Kubota hoe in question is a "sub-frame mounted backhoe" ... it is definitely not ... it's a 3-point attachment ...
Nonetheless, the frame support kit could rightly be described as a "subframe" ... and has been in the past on TBN.
FWIW:
sub-
1.
a prefix occurring originally in loanwords from Latin ( subject; subtract; subvert; subsidy ); on this model, freely attached to elements of any origin and used with the meaning "under," "below," "beneath" ( subalpine; substratum ), "slightly," "imperfectly," "nearly" ( subcolumnar; subtropical ), "secondary," "subordinate" ( subcommittee; subplot ).
   / Looking for a little advice on backhoe mounting #12
Not to belabor the point... was responding to Jim's comment about subframe hoes still using the 3 point toplink, which is definitely not correct for my setup or other true 4 point subframe BH installations I've seen. Well, TBN is always educational for me.
BTW, the toplink reinforcement is a worthwhile addition with any implement that can put heavy stress on the tractor rear diff/3 pt lift casting through the toplink. An example would be a logging winch.
   / Looking for a little advice on backhoe mounting #13
Note that I could be wrong. I was working on the assumption that if they made a reinforced top link then that would suggest that it uses that link. But you know assumptions. I was looking at a JD 8a backhoe off a tractor a few weeks ago. The subframe was attached to the backhoe. I assume (again) that the top link attached to the traditional top link of a regular three point hitch. Looking at the JD parts diagram I think I am right. I would rather have a system that bypassed the top link but a backhoe is just a dream until I build a bigger garage where I can spend a few weeks welding one up. John Deere - Parts Catalog
John Deere 5075E (A53317)
John Deere 5075E...
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2022 Kubota Z422-54 Zero Turn Mower (A56435)
2022 Kubota...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
