Sprayer Looking for a good 3 point hitch sprayer
   / Looking for a good 3 point hitch sprayer #1
Panman
I have a 2210 JD and am in need of recomendations for a nice (but economical) 3 point hitch type sprayer, preferably on that can both boom spray and/or wand spray. Not for heavy or prolonged use
   / Looking for a good 3 point hitch sprayer #2
Look to Agri-Supply, Northern Tool or Tractor Supply. All three companies offer small and relatively inexpensive sprayers. You'll probably find the most economical to be pull behind units. For a 3pt unit you may want to look at buying a "carry all" and simply strapping the sprayer to it, you can use the carry all for other purposes when not using the sprayer.
   / Looking for a good 3 point hitch sprayer #3
Here is a link to the current Agri-Supply catalog. The first several pages contain various models of sprayers. I have the 25 gallon one with a wand and I built a small carryall type platform to carry it around.
Agri-Supply catalog
   / Looking for a good 3 point hitch sprayer #4
Ditto on the carry all. Go to this thread to read an identical discussion about 3ph sprayers. When scrolling you will find good info. about the benefits of using a carry all with strap on tank.
   / Looking for a good 3 point hitch sprayer #5
</font><font color="blue" class="small">( I have a 2210 JD and am in need of recomendations for a nice (but economical) 3 point hitch type sprayer, preferably on that can both boom spray and/or wand spray. Not for heavy or prolonged use )</font>
Basically, all sprayers are made up of components available from manufacturers such as Tee-Jet. Other than the "carrier" and the boom, they are all very simular.
I farm. We contract MOST of our spraying. I have a Hahn sprayer with 60' boom. I NEEDED a smaller one for spot-spraying.
Solution...? A Fimco 55 gallon unit from TSC. I added the wand kit, a better pressure guage, and Tee-Jet 10PSI "check-valve" nozzle bodies. (That latter cuts off flow when line pressure drops below 10PSI to prevent "dribbling" after the pump has been shut down.
I've got less than $800, pump and all, in a very good little sprayer.
If you plan on using Glyphosate (Round-Up) , liquid nitrogen fertilizers, or any fungasides, take precautions to keep the pump "oiled" when not in use. (VERY corrosive materials)
The same unit is available through Agri-Supply, at a slightly reduced price, but you then have shipping to contend with.
excellent and thanks
forgot to ask, where does one get a carry all?
   / Looking for a good 3 point hitch sprayer #8
A carry all is available at Northern Tool, Agri Supply or TSC. You may also find one at your local tractor dealership who stocks a lot of implements.
   / Looking for a good 3 point hitch sprayer #9
agri supply has them for like 100
This is a bad pic of mine but this holds my sprayer, boom and hose reel on top of my box blade. Just a simple L channel frame.
   / Looking for a good 3 point hitch sprayer #10
Most TSC stores have them. Or you could build one yourself. Do a search here for Carryall. There was a recent thread on building one.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
2004 Chevrolet Suburban (A50120)
2004 Chevrolet...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
Swict 72" Bucket (A50121)
Swict 72" Bucket...
