Looking for a box blade or rear blade
   / Looking for a box blade or rear blade #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I have a TNT on this tractor and I used a borrow box blade couple of years ago for some driveway ditch work. Work pretty well....but I hesitate to borrow that again. It did pop and creak a lot. I was putting some pressure on it. Just time I get my own, since this problem has reoccurred, and though I would use it much....just times that's the attachment that is needed.
What is the best buy going on a 6-7ft box blade. I would consider a rear blade, since I could use for what limited snow we get....but for the money it doesn't seem rear blades are as beefy as a box blade. Got to get up in the dollars before they get that way.
   / Looking for a box blade or rear blade #2
I always thought I wanted a rear blade but after having several box blades I can pretty much do all I need with that. Make sure you get one that is a bit heavier than average.
   / Looking for a box blade or rear blade #3
Once you master (or get close to mastering) a box blade...it is like being able to catch a fly with chop sticks...! you can do anything...!!
T&T is paramount to mastering a box blade and hyd. rippers is a big +...If I could only have one surface implement it would be a box blade...BUT...
...being able to angle a rear blade can cut way down on the number of passes to do some of the same maintenance it would take with a b.b...
Good luck, have fun...
   / Looking for a box blade or rear blade #4
I would look for a used Gannon industrial box blade. Check the equipment rental yards as they sell their used equipment as well as renting it. Check the used equipment internet sites as well . I have seen other members find some good deals between $500 to $1250.
   / Looking for a box blade or rear blade #5
I looked at the gannon, EA, and the Bison. Calculated a price per pound and ended up with the bison.
84" Bison 3-Point Industrial Hydraulic Box Scraper Model BB21-1
   / Looking for a box blade or rear blade #6
   / Looking for a box blade or rear blade #7
I have both - Land Pride RB3596 rear blade and Bush Hog Roll Over Box blade RO720. After years of attempting to maintain my mile long gravel driveway with only a rear blade - I gave up and got the box blade along with a Land Plane Grading Scraper(Land Pride GS2584).
The rear blade is fantastic for winter snow removal. Although it does weigh 565 pounds - that's just not enough to keep it from jumping around when I would attempt to do summer maintenance. The ROBB & LPGS are the ideal implements for summer driveway maintenance.
If I had to choose only one implement for year-round driveway maintenance it would still be a rear blade. I would want one in the 1300 - 1500 pound category and either 84" or preferably 96" wide. Just MHO
BTW - I also have top link hydraulics. It is the only way to go when using ground engagement implements.
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Bucket (A55973)
Bucket (A55973)
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
