Looking for a Beaver Starter Solenoid
   / Looking for a Beaver Starter Solenoid #1
modifyit
Virginia Beach, VA
Satoh Beaver 2 wheel drive
I am attempting to rebuild a starter solenoid for my Beaver. (Too much time on my hands). I disassembled the thing and threaded the outer case then made a screw on end piece to hold it together when rewound. Problem is, this thing was fried inside and I don't know how much winding is in there and where all the ends connect. I got it close, but something is wrong with the way the coils are connected to the end of the assembly. It uses two separate windings of different gauge wire and I don't know where the 4 ends connect in relation to one another. So if someone has a burned out old solenoid lying around, maybe that would point me in the right direction.
I don't know if any of the other Satoh models use the same solenoid, but there is a good chance they are all wired similarly.
Can anyone help out here?
Thanks
Thanks
Found a starter solenoid at Rock Auto.com on closeout for $20.00. Thought I could rip into it and figure out the internal wiring. However, since the thing fit almost perfectly on my starter, I installed it and only had to rotate it slightly to line up the threaded attachment holes. The lead coming from the starter was long enough to connect to the bottom terminal. Works like new. The solenoid was listed for a 1985 Mitsubishi Mighty Max 2.3L engine. L-4. diesel.
So, in a pinch, that one could probably be found locally at most auto parts stores.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2021 Chevrolet...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
1067 (A53342)
1067 (A53342)
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
