Looking for 90mmm ID shim
/ Looking for 90mmm ID shim #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I am having a hard time locating a 90mm ID shim for an excavator pivot pin. Trying to purchase from other than the OE. Any ideas on a good supplier?
/ Looking for 90mmm ID shim #2
How thick? How many? What material? Is the OD critical, or can it be from, say, 150 mm to 180 mm? Can the ID vary slightly?
On my main boom pivot the shim split and popped out. 2mm thick. ID not critical but close. OD has more leeway. What ever material is most durable
/ Looking for 90mmm ID shim #4
Thicker than I thought, as that's very close to 14 gauge—certainly close enough to use! Consider getting some stainless steel stock and cutting them out, if necessary (or ordinary cold rolled, if it's kept greasy to prevent rust.) A cheap hole saw will get you a couple made before it gives out! (Yeah, I've done this sort of thing.) You could even use some of the stronger bronze stocks, at a higher cost.
I am looking to replace what came out. It is a shim on the main pivot. The oe shows it in the schematic. I figured they put it in for a reason.
/ Looking for 90mmm ID shim #8
someone with a CNC plasma torch, there really fairly common, and could cut most any metal, many small general fabrication shops have one,
/ Looking for 90mmm ID shim #9
Hold on I might have something. well get back to you tomorrow night.
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
2010 New Holland T8020 (A64126)
2010 New Holland...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
