Looking for 4" round LED brake/running/turn lights.
   / Looking for 4" round LED brake/running/turn lights. #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
On my Hudson trailer I've 4" round tailights enclosed by a metal box.
They are the type with 2 bolts on the back to attach to the trailer.
I've been trying to find LED replacements but have not found any 4" round w/ 2 bolts. Most are larger than 4" and don't fit.
I called Hudson parts and talked to a nice guy and he told me they had been searching also and had not found a LED replacement.
Etrailer carries a bunch on their web site but NOT in the 4" (exact) size (4 5/16) with the 2 bolts.
Does anyone know where I may find some?
Again LED, 4" are the critical parameters.
   / Looking for 4" round LED brake/running/turn lights. #2
Have you tried square ones to see if they fit?
Chris
   / Looking for 4" round LED brake/running/turn lights. #3
Sorry man, I'm using mine ;)
   / Looking for 4" round LED brake/running/turn lights. #4
Do you need to replace the fixture? Why not just replace the bulb to the new LED's?
Chris
I haven't stumbled across a square one that looked like it would fit.
I tried the Harbor Freight offering (4"+, round, 2 posts) but the "turn signal" portion that bumped out was too large.
I may end up cutting those up.
/edit
Good idea. One of the fixtures has a slight crack, so I was just going to replace them. I was surprised whrn Hudson said they couldn't find an LED replacement.
   / Looking for 4" round LED brake/running/turn lights. #7
Were those the only offering from HF? I put a set of round LEDs from HF into a square enclosure on my tow behind boom lift a couple years ago. No problems with them. They didn't have a bumped out part on them.
   / Looking for 4" round LED brake/running/turn lights. #8
Weld a piece over the back of the light mount then you can drill a hole to put a rubber mounted light in it.
This place has several 4'' round lights. IDK if any of them will work.
Red Stop, Tail and Turn Lights : GPartsInc.com
   / Looking for 4" round LED brake/running/turn lights. #10
2018 Genie GTH-636 (A50123)
2018 Genie GTH-636...
2007 Mack Winch Truck (A53117)
2007 Mack Winch...
6" & 8" I BEAMS, 2" X 2" TUBING, 2" X 2"ANGLE IRON (A51247)
6" & 8" I BEAMS...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
