Looking at New Hay Rake
   / Looking at New Hay Rake
I will. Thank you sir.
   / Looking at New Hay Rake #12
Mine is being pulled length ways. Its too long to make turns.
Being on some mountain roads I have the last few days can understand that. Been while since have been on such sharp curves. The turning off any road anything real long can be issue in narrow gate or such.
   / Looking at New Hay Rake #13
V-Rakes. Vermeer or Kuhn?
Had a similar dilemma this spring. Wanted to move from a side delivery to a V style. Looked at the major 3 carted rakes in my area. Kuhn, Vermeer and New Holland. All three good high clearance rakes. The Kuhn and Vermeer have their wheels double mounted on arms. The New Holland has its wheels mounted independently. Although I do like the center kicker wheels of the Vermeer better dealer was no good to work with. (I never have liked that salesman.) Ended up buying a New Holland Procart 1022 with center wheel. Raked about 175 acres this year with it. Did real good job raking. In thick hay (2.5+ton/acre) I had trouble getting the hay to go through the throat. Have a 4 foot baler. A 5 foot wide baler would have helped with this.
Learned after purchasing the New Holland that you can get them with a hydraulic kit on the wings to adjust the throat while raking. This would make clearing clogs easier I believe. I may look at adding it to mine before next year.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58216)
5-6 YD BLUE LINE...
MILWAUKEE HAMMER DRILL & WHEEL PULLER SET (A58374)
MILWAUKEE HAMMER...
