Buying Advice Looking at JD1025R, JD 2520R, & Kubota BX25D
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #1
gfreek
Originally started to look at the BX25D with backhoe and loader, and a JD 1025R with backhoe and loader... then thought about going bigger to the JD 2 series, the 2520R (but they are phasing those out) replacing it with 2025R. So the dilemma is try to find a 2520 or wait a month and get the new model 2025. Both est around same price with implements......Trading in a 2005 Cub Cadet 6284... Any thoughts??
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #2
The BX25D and the JD1025R are smaller than what you currently have.
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #3
What jobs do you plan on doing with the tractor
Yes the Kubota and JD 1 series is smaller than what I have now...They were my first look, but now looking at next size up... I plan on doing some drain tile, smaller pine & poplar stumps,clean drain ditch besides driveways, under ground water line repair at shop, post holes ...
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #5
I think I would wait for the new model JD2025, if the price is going to be the same as the 2520R.
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #6
And go big or go home.
   / Looking at JD1025R, JD 2520R, & Kubota BX25D #7
Out of the 2 sub compacts you mentioned I would go with the BX hands downs. The BX has a cat 1 3PH. The 1 series is limited cat 1 so it does not pick up as high. You can curl and raise the loader on the BX, you can't on the 1 series. The BX also has a curved boom loader for better visibility. The BX has way more power than a 1 series even though they are rated the same. The 1 series has a goofy setup on the 3PH. They all come with a tarp strap to keep the lift arm from rubbing the tire when you don't have a implement on it.
If you want something bigger I would also look at a B2620. It has a 3 range hydro. The 2025 is 2.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
2021 KENWORTH T680 SLEEPER (A51222)
2021 KENWORTH T680...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
1998 MACK DM690S MIXER TRUCK (A50854)
1998 MACK DM690S...
