Looking at IH 444 gas. Owner says brakes touchy and 3 point leaks down.
   / Looking at IH 444 gas. Owner says brakes touchy and 3 point leaks down. #1
ShowroomShine
Raleigh NC
2019 Case IH 55A
Looking at a IH 444 gas. Pictures look good and it is a one owner tractor, but it has only been used a few hours in the past 6 years he says.
I asked about any problems and he says the brakes are touchy and the 3 point leaks down after a couple of days. As long as the 3 point does not leak down in 10 minutes I'm not that worried about that.
How hard are the brakes to adjust on these tractors?
He also says it has 3600 hrs on a tach that hasent worked in years, and the engine was rebuilt in the 80's. I'm a little concerned about the rebuild.
Anything else I should be looking for?
There is also a 454 close to me, would I be better served to get that one or stick with the 444? It will only be used for light work like mowing, moving hay, and aerating pastures.
   / Looking at IH 444 gas. Owner says brakes touchy and 3 point leaks down. #2
If it is an older 444, 1967-71 made in USA it should be a C-153 engine. It had an inherent problem with the oil pump. To keep it short look up my post from a year ago in CASE IH forum detailing the issue and fix, sorry I dont know how to link it to here. other than that it is a good little tractor but has an extremly stiff clutch pedal, something to keep in mind if your wife is going to run it.
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F450...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
