Looking at compact utility tractors
   / Looking at compact utility tractors #1
Giesetraveler
St. Paul, Property No. Central MN
Ford 5000 gas
Hi Folks,
After trying to turn untill pasture of 30+yrs my 500 Artic cat is asking for a little help. I will be looking at a Yanmar 19 hp tomorrow but don't know the model yet. I have been looking at gas 20-40 hp used rigs. Is a 19 hp 4wd diesel anywhere comprable?
I can see using a small disk and harrow and have several small plots 1/2 to 5 ac. In size totaling maybe 25 ac. Max all the rest of the 90 is timber. I have a Kunz small plow and it along with a disc will do about all I need with a small tractor. As a newbie to tractors I'm open to any help and coments.
Was looking at Fords before stumbling on this Yanmar.
   / Looking at compact utility tractors #2
Welcome to TBN. :)
   / Looking at compact utility tractors #3
Try the website TractorData,com Or scroll down TBN's forums for tractors makes and models. In the end, the final choice is yours, but I cannot envision 19HP being enough. Engine HP differs from PTO HP. Good Luck.:welcome::tractor:
Thanks,
I'm also not sure 19 hp is enough. This is a diesel and I have read you can do more with less hp because of their power curve but I have no experience.
Just starting to look so am not is a screeming hurry.
thanks again for the fast response.
   / Looking at compact utility tractors #5
When you say "turn" do you mean plow? If so, 40 HP would be about right for 25 acres.
Yes, i am trying to take fallow land back from Mom nature:)
My soil is sandy loam my tillable portion has no rocks but lots of tree roots...
Sod layer is 3 inches and ph 5.6 fine sand below. Will be adding lime this Fall.
Once plowed and planted I think the hardest work will be done. Maybe I should hire someone to do it and use a smaller tractor thereafter? My experience with having someone else do the work has led to uneven fields and poorly harrowed it!s hard to walk on so I am a little gun shy.
1266 (A50490)
1266 (A50490)
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2007 Ford Edge SEL SUV (A50324)
2007 Ford Edge SEL...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
