Buying Advice looking at buying a ford 4000 industrail
   / looking at buying a ford 4000 industrail #1
moonmonkey
middleburg fl
l300f kubota
hey guys im looking at buying a ford 4000 industrail tractor. it has a generic or home made front end loader on it with a 4and a1/2 foot bucket. the controls leak some fluid but rams and hoses are pretty good. it is a gas engine ,and cranks up and runs well ,it does smoke a little, but had been sitting a while. tires are all fair to good, i drove it and it goes forward and reverse fine but shifter jumps out of what ever gear is forward left position runs all day in 2nd or 3rd, the only thing keeping it from being a working tractor is it has bad power steering.,,, before i buy it how expensive can this be? it is just super hard to turn the wheel, 3 point and lift all work pto spins. i will include pics i took she wants $3000.00 but i think i can get it for $2000-$2500 ,any ideas????
   / looking at buying a ford 4000 industrail #2
you just said that it has 2 major probs.1 the power steering is shot an needs major work.2 it jumps out of gear in certain gears.so that is way to dangerious for you an your kids tobe around if it decides to jump out of gear.you can find a better tractor than that money pitt.even if you could fix it you might be looking at $2000 or more to get it right plus new tires.
   / looking at buying a ford 4000 industrail #3
Not a homemade loader at all. Looks like a model 730 iirc. Power steering is iffy though. Could be simple, and could be a lot of money. Just depends on the design. Some old fords had separate pumps and resivoirs for the PS. And they didn't hold much. So it could just be low or out.
The trans is iffy too. I had a old ford with the same issue. And it was a busted gear.
All in all, it sounds like a project tractor at the moment. If you aren't ready, walk away. If you want the project...given the potential cost, $1000-$1500 tops imo
   / looking at buying a ford 4000 industrail #4
Hi: I'm new today and not a computer nut can someone please tell me how do I start a new question I have a problem with my tractor and need help?
   / looking at buying a ford 4000 industrail #5
From the main page, pick the sub forum you want. At the top is a button that says new thread.
   / looking at buying a ford 4000 industrail #6
not worth 3000 if ps is out and jumps out of gear badly....
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
