Looking at a JD 990
/ Looking at a JD 990 #1
Champy
Indiana
John Deere 990
I've been looking at nearly every brand of CUT I can find around here, and after much confusion, research, and debate (and spousal approvals), I have settled on a JD990. Pricing quoted from 3 dealers I've visited has been roughly:
JD 990 - $!6,700 (MFWD)
300CX FEL - $3700
6' LX Rotary Cutter - $1700
Are these "good" prices? Should I keep shopping around? Any comments; concerns; watchouts regarding a 990? BTW - will be working on 35 acres; cleaning it up to make a tree farm; rolling and currently in soybeans
Thanks all..........
/ Looking at a JD 990 #2
I think that is pretty close to list price right off of the (build your own) section on the deere website.
/ Looking at a JD 990 #3
300CX FEL - $3700
That is a decent quote. It is a value priced tractor from the start so the discount factor is not as high as the other higher margin tractors in the deere lineup.
/ Looking at a JD 990 #4
sounds good to me, in 15 years those tractors have not gone up in price much. A 1070 woulda set you back $19,000 in 1992.
I would suggest getting the power beyond kit added now.
Somebody here mentioned that JD is having trouble stocking yanmar based replacement parts for the 50, 55, 70 series tractors if true and the trend continues, the 90 series might suffer in the future.
I am not worried about this personally but have not needed parts lately either.
Tires: if you havent searched past posts and opinions here yet and are unsure I vote for r-1s. If you think you will venture off the farm to do some landscaping or other various tractor services then I would suggest the more durable r-4.
/ Looking at a JD 990 #5
Steve is right about th epower beyond. Do it up front. I just recently added an 8B backhoe to mine.
Thanks everyone for the comments......Some basic followup questions ......
> What does Power Beyond do? (why would I need/want it)
> R-1 tires vs. R-4's...which way to go?
I plan on moving snow on a paved drive in winter, should I opt for the R-4's, or use R-1's? I will also have some road time on the tractor moving from one field to another....if this matters. Otherwise it will be some lightweight FEL work; bush hogging overgrown pastures; etc... I have about 25 ac of gently rolling terrain currently in soybeans and 10 ac woods/weeds/creek.
Thanks again
/ Looking at a JD 990 #7
Thanks again
The power beyond brings hydraulics to the back of the tractor. Allowing you to easily connect a 3pt wood splitter, backhoe, 3pt snowblower with hydraulic chute adjustment. Anything you may hook up back there that needs a hydraulic feed. It will add a little expense to the tractor I would think in the few hundred dollar range. Maybe work it into the deal as throw-in. A seal the deal point.
I would say R4's are best for you. They are an aggressive tread industrial tire that is the best multipupose (pavement, woods, fields etc) tire for the machine. The R1's are an excellent aggressive agricultural tire with a softer compound. Definetly not good for pavement because they wear more easily. It is more of a single use tire. Info below from John Deere Website.
R1 tire
An R1 tire is used primarily for general dry land farming or where soil conditions are average to ideal. An R1 tire offers the most aggressive traction of these 3 designations.
R3 tire
An R3 tire is used primarily for golf course and mowing applications to minimize turf damage. An R3 tire tread is less aggressive than an R1 or R4 tire, and the tread depth is approximately half as deep as an R1 tire.
R4 tire
An R4 tire is best in industrial or highway department work applications. These tires offer excellent traction on harder surfaces such as construction lots and are less aggressive on turf than an R1 tire. An R4 tire is more aggressive than an R3 tire, however, it is less aggressive than an R1 tire. An R4 tread depth is about 70 percent as deep as an R1 tire.
By the way.......after visiting 3 different JD dealers and getting quotes, the only discounts they offered is $100 off if I buy two implements......
I even offered to pay full price in cash and got no movement on pricing!
/ Looking at a JD 990 #9
tell them it is for agricultural use to avoid sales tax, they may ask for your SSN or fed tax id no.
You will get an automatic discount buy buying woods or landpride implements and get same quality.
have them install rear tires at wide stance and fill them with chloride or RIMGARD
/ Looking at a JD 990 #10
I started this same process you are at over a year ago and still haven't bought...but I've learned a lot through this site and through shopping around and testing different tractors.
Originally, I was looking at a 990. In my opinion, you should take a hard look at the JD 5103. I was recently quoted $17,800 for a 5103 w/ loader, vertical exhaust, arm rests, and R4s. You are getting a LOT more power for close to the same $$$. I drove one around the lot and was impressed about how agile they are. You will also have a hard time finding anything negative about the 03s on these boards. Depending on what my CPA says at the end of the year, I'll be getting an 03 as soon as possible.
/ Looking at a JD 990 #11
Also, you might think of jumping up to an MX6 shredder. More durable and more powerful.
/ Looking at a JD 990 #12
Unless you have decided 4 wheel drive is required. Then this would not be an option here.
/ Looking at a JD 990 #13
I vote for the R1's and the 4wd 990 over the 2wd 5103. Since you are not going to use your tractor on the lawn, the only advantage R4's would give you is slightly better durability in the woods. R1's are a lot better in the snow,mud,and tilled ground and it sounds like you will see these. In my opinion, the single biggest reason to get a new tractor is 4wd which almost doubles the capability of a loader tractor compared to a 2wd of equal weight and power, and also results in improved offroad fuel economy.
I have had tire discussions with most of the dealers in my area (southern Indiana), and they all agree for the most part that about 80%+ of the CUT sales they are making go out the door with R-4's...........perhaps this would affect resale or maybe everyone else knows better than I do what is the best all-around tire setup locally.
> I looked at the 5103's but when I found out they were only 2WD they came off the short list.
> currently comparing with a Kubota L4400........not sure if I like the hydrostatic pedal (heel/toe); and the loader controls are up fairly high, feels like I'm waving to everyone.
/ Looking at a JD 990 #15
I had a Kubota B7500 at one point. The two problems you mentioned were a little bit of a pain for me. The heel/toe pedal made any work looking behind you a real pain in the knee (bad knees anyway but still) . Its a real awkward bend when working with am implement that requires frequent checking over the shoulder. The loader lever is a bit of a reach and can get a little tiresome. I guess I am mixed on that because I fnd my leg hitting the deere bucket control lever from time to time. Causing me to roll the bucket.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63689)
2012 MACK Tender...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
Homemade Utility Trailer (A62613)
Homemade Utility...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
