Looking at a 1440 -(I need some help)
   / Looking at a 1440 -(I need some help) #1
Task
Hi all, My first time posting here, just found this site a couple days ago. I'm looking at a 1440 with about 900 hrs. The tractor looks straight no dings, even the bucket. 1525 MF loader
A few questions 1).What is the life of the turbo charged engine? 2).How are they in cold weather -20? 3). Anyone know the price of a soft side cab? Anything else you can tell me about these would be appreciated.
All the best in the new year!
I took a look see at this tractor (cut). It is a full feature model 16x16 Power shuttle trany, R4 tires, diff lock, 4x4, the loader is good for 'bout 1900 lbs.
   / Looking at a 1440 -(I need some help) #3
I wish I could be of more help. When I was purchasing my last tractor, I had looked at the 1433 and 1440. I ended up with a 1445, but if I had to pick between the 1433 and 1440, I was going to go with the 1433. PTO horsepower was not an issue for me at the time (26 vs 31), and I also was not sure about the turbo. To be honest I haven't heard any complaints about the turbos - and I assume they are real solid. That being said, the 1433 and 1440 is the pretty much the same tractor except for the turbo. If you are looking to do some heavy work, my feeling is that the best thing to look for in a compact tractor is weight. Even the 1433 would have enough horsepower that traction would become an issue long before the extra power of the turbo could be used. The only caveat to this line of thought is if the tractor is going to be used primarily for applications like mowing, where the extra PTO HP can let you run a larger cutter. I eventually went with the 1445 because it was a much heavier machine weighing about 1,000 lbs more than the 1433/1440.
I'm not sure what your plans for the tractor are, and at what price the 1440 is being offered for, but if you like the 1440 - you should also give the 1433 a look as well since it will probably be cheaper and will be able to handle just about everything the 1440 will. Although I may not be providing you the help you are looking for, I have at least looked at the 1440V when purchasing my last tractor, and I wanted to give you my thoughts about it.
Good luck and happy tractor hunting!
   / Looking at a 1440 -(I need some help) #4
Those turbos will run forever it seems like. We have serviced some of these tractors with over 3500 hours with the same turbo. -20 will not be an issue for that tractor, since it has a pre-heater.
Thanks for the replys, I took a leap of faith and bought the tractor. It's tough to find CUTs in the condition and price around here. I've been looking for over a year. Had to drive 300 miles.
   / Looking at a 1440 -(I need some help) #6
I don't know much about the model numbers, but I just bought a 1429 (which I think is similar) and so far I love it. I've been using it to clean up a bunch of pine trees that blew down on my property, and it's making quick work of it.
   / Looking at a 1440 -(I need some help) #7
Do we get pics?? :)
Just remember, let it idle for a minute or 2 after use, so the turbo can cool off, so the oil does not 'coke' in the turbo!!
You will love the powershuttle, I sure do, and will never go back to a hydro ever again!!
Power shuttle 16x16 spd with creeper gears and quick detach bucket.
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
