Rotary Cutter looking at 6ft rotary cutters
   / looking at 6ft rotary cutters #1
haybaler9
I'm trying to decide between the john deere and bush hog rotary cutters. there both the same price. I had a five foot john deere that I never had a problem with, but i've been told bush hogs are better. I'm going with the medium duty over the light one because of the round pan (stump jumper)
the only difference I can see is the john deere has high lift blades thats good for layed down grass. I would love to hear some experiences from people on both brands.
   / looking at 6ft rotary cutters #2
I just bought a Bush Hog 286. I managed to get about 2 hours of use before winter set in. Well built, sturdy, and good finish. I don't have much experience with the Deere, other than all of 'em I priced were $300 to $500 higher than the price I went with on the Bush Hog.
No one has a better reputation in the mower business.
   / looking at 6ft rotary cutters #3
Hi haybaler9,
I have the MX-5, and it's bulletproof... I can't usher a word of complaint--it's shredded everything I've driven over, right up to 3 inch yellow birch and an unfortunate antique wagon axle hub, and aside from a couple dents, scrapes, and character to the blades, it's my baby...
If I were to buy again, (even though it's not green!) i would be tempted to look at the Woods brushbull... higher gearbox rating, splined PTO shaft, heavier by a fair shake... but from all I've heard, I probably won't get a chance to purchase a "bush hog" again for many years...
Don't know squat about Bush Hog brand, so can't help you there! But must be something to be said for being the namesake of the shredder industry...
Good luck; if you have a JD--keep it green--prettier package if you ever sell! /forums/images/graemlins/grin.gif
Happy tractoring! /forums/images/graemlins/cool.gif
   / looking at 6ft rotary cutters #4
I can't speak for the 6', but I have an LX-4 from JD. I've only got 20 PTO HP so it seems well matched. It cuts well, but I've had to replace two different seals (first time under warranty) in about 18 months. The transmission had also vibrated lose to where only one of the 4 bolts holding it to the deck were tight. I don't know if it was the dealer's fault after the first seal fix or not. I know it's a light duty cutter, but I've not put that many hours on it. I can say it cut weeds and brush up to 7' tall and didn't bog down on much.
It also has a Transmission from China if that matters.
I just got it back this week and other than turning it up to make sure it worked (it was virtualy vibration free) I've not used it again.
I'm not so sure I'd buy another; only because of the seal issue. I would have to look long and hard. However, I don't plan on replacing it so it's a mute point. The slip clutch has worked flawlessly and saved me hours of frustration replacing shear bolts, not to mention the bad words. I believe the stump jumper on mine is also convex.
Here on the California Central Coast, there are not a lot of local farm/tractor suppliers so my initial choices were limited.
   / looking at 6ft rotary cutters #5
Joe, Was it the gearbox lower oil seal? From what I've understood from talking to locals and the dealer I bought it from before I found this site, that if you're mowing heavy stuff, the lower oil seal is going to go out. Mine went out about 300 hrs ago. I did what I was told to do, pump the gearbox full of grease and add to it about every 6 months. I've had no problems with the mower since. Might save you some seal replacement money. Other feel free to correct me if I'm wrong.
   / looking at 6ft rotary cutters #6
Not trying to be confrontational, but are there statistics to substantiate this statement?
<font color="red"> </font> No one has a better reputation in the mower business.
<font color="blue"> </font>
let's just say they have the longest reputation. I'm not trying to start color wars here, I just want peoples experiences with these two brands.
i know john deere makes there own gear boxes on the new LX5/LX6 (not sure about LX4) so I assume there made in the US. I know the bush hog has a double seal setup on the bottom to prevent leaks, does anyone know if deere is the same? i wish the dealer would let me take the machine apart and put it back together before I bought it /forums/images/graemlins/smile.gif
I would really like to hear from someone that's tryed the new MX6 with the high lift blades to tell me if it really cuts better than the normal blades.
   / looking at 6ft rotary cutters #8
Haybaler,
If you are looking at the medium duty units, do look into the woods line of BrushBull cutters. They are THE easiest to change blades on. The others will have you using a 6' bar and an impact wrench (if you are lucky) or else you will have to burn off the bolt/nut with an Ox/Ac torch.
They are also the best built (compare weight, blade size, gear box, stump jumper diameter,etc)
Once you get into the medium duty units, the quality goes up as they are bought by municipalities and commercial users, so they are all good, some are just better for your uses.
jb
   / looking at 6ft rotary cutters #9
You want statistics? Just count how many people refer to them as "bush hogs". Even when they're some other brand. Bush Hog is the first name to roll off of everyone's tongue when talking about rough-cut mowers.
After owning Woods, Rhino, Deere, KK, MF, and a few others, I'd take a Bush Hog mower over any of the rest. And that's no statistic. Just actual "hands on" experience.
   / looking at 6ft rotary cutters #10
I've used a 286 for several years with zero problems. Most of my cutting right now is relatively light, but it has seen some extreme duty in the past. Chains add to the cost, but I recommend them.
As for the blade style, Bushhog's website parts availability indicates "uplift" blades or "double edged" blades for the 286. I suspect that JD nor Bushhog has the market cornered on uplift or high-lift blades, so that shouldn't be a dealbreaker for any good cutter.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
(1) Drum of Algicide (A51573)
(1) Drum of...
2020 JOHN DEERE CP690 LOT IDENTIFIER 190 (A53084)
2020 JOHN DEERE...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51573)
1986 Peterbilt 359...
