dmccarty
Super Star Member
Sunday I was finally able to get some tractor work done. I have been working 10-15 hour days plus weekends. But that is over and I can finally start catching up on my chores. Way behind I am.
I had figured I had about 8 hours of mowing to do and I almost took a half a day from work to start but that did not work out. So there was Saturday. Well it rained real hard Saturday morning so that left Sunday afternoon.
The log book said the last time I started the tractor was the end of July. Added five gallons of fuel, PS, and off I went mowing. I mowed the edge of the driveway and then got into a cleared area on our house front. Just grass about 3-4 feet tall. There is one area that goes back into the woods that I want to keep open so I went back down that way and it was pretty clean. I had already mowed this back in July and it had not grown up. There is a mess of blackberry bushes and saplings I wanted to clean up so I backed into the mess a few times and clean it right up. Then I mowed back to the driveway. This is about 400 feet.
I get back to the driveway, cross it, and started mowing a bit of grass on the other side. There is quite a bit of up and down crossing the driveway so I looked back to see how the rotary cutter was cutting. And the MX 6 was at a sharp angle instead of parallel to the ground!
I quickly realized that this was not good. From the seat I could see that the upper pin on the 3PH had slipped off! At this point I'm in the middle of the driveway. I can't stop the tractor at this spot since it would completely block our way out. So killed the PTO and I pulled forward 100 feet and stopped. There is a ball that holds the upper arm of the 3PH and it along with the linchpin is missing. I have plenty of pin but without the ball I wont be able to move the tractor.
Best I can tell is that when I backed into the heavy brush a sapling unclipped and then pulled out the linchpin. Somewhere along the line the shaft pulled out of the ball and the ball fell out of the 3PH. So I retraced my steps several times. Course the ball is brown. its heavy. In heavy grass. With leaves. Chance of finding the ball are slim and none.
I really don't want to be walking were I'm walking. We have had some freezes but there can still be ticks and chiggers and I had not dressed/sprayed my clothes to keep off the biting bugs.
So I look. See nothing. Figured I would drive into down and see if the farm store had the part which was going to be doubtful. Reality was that I would have to send a note to JD and have them ship me the part.
Walking up the driveway I find the ball. The pin had slipped out of the ball cutting the grass along the driveway. When I pulled forward to unblock the driveway the ball had vibrated out of the 3PH.
WHEW!
Put it all back together lickity split and it was back to mowing. I mowed about 1/3 of and acre of heavy brush and saplings with no problems. I have done this numerous times and never had a linchpin yanked off like that.
In the future I'll keep an eye on those pins.
The tractor still amazes me. The stuff I cut down would have taken days to do with a chainsaw and brush cutter. Took maybe 30-45 minutes. The front field had "grass" with lots of white fluffy seeds. They coverered the front panels over the engine. They were about 1/2 thick in places. Engine never got warm at all. Cleaned it off when I finished mowing. Good design. Heck of a machine.
Later,
Dan
WHEW!
Later,
Dan
