Backhoe LOOK at the Backhoe Reach!
   / LOOK at the Backhoe Reach! #2
hill said:
This plumb amazes me - the reach of the backhoe on this old Kubota tractor is easily five feet more than my BH75.
The seller says that the hoe is made for his tractor, a B8200.
Kubota B8200 Tractor w/ large backhoe/loader 4X4 Diesel - (item 140143496565 end time Aug-11-07 18:00:00 PDT)
12 ft ?
Basically, I don't believe it. Either the seller has made an error or it is a misprint. It isn't THAT big of a tractor and the pictures only show the hoe to be about in proportion to the tractor.
   / LOOK at the Backhoe Reach! #3
Why not? Clearly the dipperstick and boom go from the subframe to well above the ROPS. I've seen "long reach" excavators for mucking out ponds from the bank and for installing sanitary sewer that I've designed 30 feet in the ground, so this isn't that strange of a monster.
What I'm blown away by is that someone ACTUALLY BUILT a long-reach BH assembly for a Kubota tractor. Doesn't seem like there'd be much of a market for that type of thing.
This is a very, very rare bird, indeed. You're going to sacrafice a bit in overall capacity. Breakout force of the bucket itself would be similar to a "normal" BH, but you loose mechanical advantage over the long dipperstick and boom. Lifting a bucket-full won't be a problem, but you won't get much "help" when trying to yank something out of the ground...it'll have to be all bucket.
Pretty darn cool, if you ask me.
The seller emailed: "it's a McConnell KM190. It is made for this model Kubota".
I'd agree with you, Keith, about the loss of brute strength, but boy, would that be an aid to trenching!
   / LOOK at the Backhoe Reach! #5
They may have used bigger boom and stick cyls to get good force. That would sacrifice speed tho, unless PTO driven from an aux pump.
Reach is wonderful. I wish the 11' on my Mahindra 7520 was more. Biggest option on the package tho.
larry
larry
The more I look at that setup the better I like it. I don't know anything about the model but if I hadn't just bought a B7800 and knew what I know now this old Kubota would be of a serious interest to me. Buy that, buy a more powerful Kubota engine, paint up the hoe and have what I'd think of as the ideal B series sized tractor - especially if the old models are heavier than the current run of featherweights.
Is your 11' hoe Mahindra made, or an aftermarket brand? And does it attach to a subframe?
   / LOOK at the Backhoe Reach! #7
I believe Bradco supplies the hoes for Mahindra. Mine is a #511 and mounts to a massive subframe. Sturdy setup. I believe the tractor would handle 14' easily. Not an option when I bought, or even yet. Darn.
larry
   / LOOK at the Backhoe Reach! #8
What I don’t believe is… this SAME tractor and description is in a TBN classified add on this forum classified section… BUT it is in Jamestown,, ND… NOT Winber, Pa. like the Ebay listing shows. Is this perhaps a bogus Ebay sale??? Look yourself, Google “McConnell KM190” it will give you the link to the TBN classified link…. ??? KennyV.
   / LOOK at the Backhoe Reach! #9
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50322)
2015 Clarke Power...
Backhoe Bucket (A50515)
Backhoe Bucket...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
