Long-time "guest"
   / Long-time "guest" #1
rwdenney
Kubota BX2660
I've used TBN for several years as a warehouse of information. Life precludes much more than that, but it was time to register fair and square.
Land: 6 acres, 4 covered with 90-foot white pines (Grrr!), plus many other decorative hardwoods (leaf-makers, especially a couple of mature Chineses chestnut trees). About 3000 pines (yes, too many for the land they are on). They fall routinely, and I find myself having to deal with it even when we are forced to hire a tree company to take away the carcasse. And then there's the 4" layer of interwoven pine needles they deposit every fall. Gravel driveway 1000 feet long over easement between two other lots. Northern Virginia area which seems to get a 2-3-foot snow dump every few years.
Tractors: 2001ish Kubota G1900, 60" mid-mower, sprayer trailer, Cylone Rake, snow plow (unused becaus of the unpleasantness of removing the deck which is a required first step to installing the plow). It's an indestructable mower and it's easy enough for the wife to use. I've pushed big snow with it, but I'm rather surprised I didn't break it in the process.
2010 Kubota BX2660, FEL, 6' TSC rear blade (used for driveway maintenance where it has worked very well, though I had to turn the pins inward to fit the BX 3PH comfortably), Leinbach pine straw rake, 60" mid-mower, filled turf tires.
Snow removal: Troy-Bilt walk-behind track-driven 28" two-stage. Slow but effective, if the snow isn't over the top of the auger scoop. Transmission has blown up once in 75 hours of use--our situation is usually no challenge, but when it's bad (e.g., February, 2010), we have run this for three straight days to dig out. The track drive is excellent for gravel driveways, unless the snow is wet on the bottom, in which case it will load up the track drive with ice and require a lot of fiddling. 2660 FEL is the backup plan for when the walk-behind can't hack it.
Lusting for: BXpanded snow plow, pallet/brush forks, bucket expander.
Real needs: Landscape rake, ratchet rake, bucket hooks.
Me: civil engineer who travels on gubmint business over 50%. Like to do things myself, but don't always have time. Former (by many decades) auto mechanic; decently equipped shop (except would like more welding stuff and the skills to use it well). Not afraid to tackle most repairs and projects as needed, and when time permits.
Rick "now officially introduced, but still an occasional lurker" Denney
   / Long-time "guest" #3
Welcome Rick
Sounds like all you need is 42,000 miles of Christmas lights and wow what a show!
Seriously, that's a bunch if trees. What's your plan? Any timber value? Instead of a corn maze, you could make a pine maze...
Welcome aboard!!
Dean
   / Long-time "guest"
Given the greenery is about 75 feet up, you'd have to be pretty tall to be fooled by this maze.
There is no timber value. White pine is too weak to make good lumber. It can be pulped for paper, but transportation costs make it unprofitable given our distances from the nearest mills. It's too resinous for firewood; it will coke up a chimney in a hurry.
They break in strange and mysterious ways. We had three that were closest to the house that broke all at the same height--about 30 feet up. They were 80 feet tall, and 50 feet from the house, which is the direction they fell. You do the math. The tops wiped the spider webs off the side of the house on their way down. In the pic, you can see where it broke in the upper left corner, and where it fell in the lower right (up against the house). Too close for comfort.
The next two pics are from a three or four years ago, when one tree broke right out of the ground (healthy tree with an ice load it could not handle), and another one broke at a split crown 12 feet up. This kind of stuff happens all the time here. We've spent more than the cost of that BX2660 on tree services, and still have to do most of the subsequent cleanup ourselves. The trees in the top of the third picture, that look close to the house, are going bye-bye this week--about 100 trees that are just too close. I think a landscape rake is on Santa's list.
Oh, and we get snow, too. Not often enough to warrant real preparation, but bad enough to lock us down for a week if we aren't prepared. The fourth picture is between a 30" dump and a 15" dump that were four days apart in February 2010.
Plenty of work for a tractor to do!
Rick "and then there's the undergrowth" Denney
   / Long-time "guest" #7
Welcome Rick
Your project looks like fun.:laughing:
   / Long-time "guest" #9
Re: revia buy
Welcome to TBN
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
Deere 325G (A50120)
Deere 325G (A50120)
Quick Attach Pallet Forks (A47384)
Quick Attach...
