Long term storage with synthetic oil
   / Long term storage with synthetic oil #1
Anonymous Poster
Epic Contributor
I have two machines that get intermittent use, both with 2cyl gas 4 cycle engines. One is a ztr mower that gets used about 20 times during the summer. The other is a Gillette generator that gets used 2 or 3 times a year. I am thinking of using synthetic oil in both but have heard that this oil does not coat as well as pet. oils and that the motors could rust internally during long term storage. Has anybody had any experience with this?
   / Long term storage with synthetic oil #3
The synthetics manufacturers all claim that synthetics excel at this type of usage. I use it in a generator that has sat for almost two years without being started and it's been fine. I also use the two-cycle oil in a number of things that are used similarly, with very good results. There's no truth to the rumor that synthetic doesn't coat as well and, more importantly, synthetic doesn't suffer the effects of aging due to evaporation nearly as much as petroleum lubes do.
MarkC
   / Long term storage with synthetic oil #4
Welcome back, stranger./w3tcompact/icons/wink.gif
Bird
   / Long term storage with synthetic oil #5
Bird - You forgot to say "no pun intended". /w3tcompact/icons/wink.gif
MarkC
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
WB Mower (A50120)
WB Mower (A50120)
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
