Long term (or high hour) reviews on RK55?
   / Long term (or high hour) reviews on RK55? #11
I've got to side with those suggesting you look into TYM; if you've got a dealer you get a good feeling from, one who will support you and bat for you should the machine need work, I'd take that over RK any day. The machines are good, especially when they've been set up properly- dealer prep is extremely important.
   / Long term (or high hour) reviews on RK55? #12
I sold mine with 356 hours; it was competent, lifted everything I needed, and had a great backhoe. I pulled a two-bottom 18-inch plow with no issues. It arrived with a bad ECU, and they had to pull the wiring harness since there was a new version. The alternator went out at 6 months and had to be replaced. Just like TYM the RK has the same issues with the front tires falling out of the axle with zero warning. The service tech at RK stated they fixed that issue, and it should not happen again.
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
1629 (A57192)
1629 (A57192)
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
2016 Toro Workman GTX Utility Cart (A56857)
2016 Toro Workman...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
