Tiller Long Model 1537 Tiller Attachment
   / Long Model 1537 Tiller Attachment #1
fightingeagle
Anyone have any information on this tiller, maybe how i can go about finding a manual for it? Redoing bearings/races/seals - have parts on order. Last "user" didn't periodically check oil and ran it dry. The bearing next to the pinion gear exploded due the lack of lubrication and dinged up the ring and pinion gears. They should be ok. It also busted out the straight keys and a chunks of the shaft on the ring gear shaft - one one each side of the pumpkin. I think Long still makes tractors but the name has changed w/ new owners a couple times. I know it is at least 15 years old as it was picked up at a farm sale and it was a "used" implement then. Any info on who Long has become? Maybe I could contact them.
   / Long Model 1537 Tiller Attachment #2
at some point lg from korea made some of the longs, i'm not 100% sure but i would be the implements that bear their name were built on a contract with some other company. the lg name has changed several times and is now ls mtron company still in korea. it is possible at 15 years old it was even when goldstar was at the helm. i would try to contact a montana dealer, because they get their units from ls also ls is starting to sell under their own name also so you might want to try that route. this is probably you're best option.
   / Long Model 1537 Tiller Attachment #4
I am looking for a service/parts breakdown. Did you ever find one?
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
2010 Ford Crown Victoria Sedan (A55853)
2010 Ford Crown...
Shell Vintage Decorative Fuel Pump (A55853)
Shell Vintage...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
