LONG front end loader moves slow ?
   / LONG front end loader moves slow ? #1
Matthew27808
BATH
1998 New Holland, 1725 , 1981 Long 510
Hi guys
I have a front end loader that rises very slow but is a little faster when the RPM are up. The pump is fine, thats verified. When you pull the control lever it drops about a inch and then goes up slowly but is still very strong lifting and the curl is fine. Could it be that one or both the Lifting Rams have bad packing ? Any thoughts ?
   / LONG front end loader moves slow ? #2
If you quick disconnects on the hoses I would suggest carefully swapping the hoses for lift / lower to the curl / dump function. If the loader lifts fine but curl now is slow you could have valve issue.
Dropping a little before raising could be a load check leaking.
I don't have quick connect but I still can switch them. That way if that don't work it would eliminate the valve.Thanks, I'll try that.
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2021 Chevrolet Silverado Pickup Truck (A51039)
2021 Chevrolet...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
