Long block vs normal Ford 4500?
/ Long block vs normal Ford 4500? #1
Armymutt
Sanford, NC
JD 455
I discovered that my 67 Ford 4500 3 cyl diesel has a cracked block between cylinders 2&3. Looking for a new block or engine. I found a site that lists a long block and a normal block, both for the 4500. What's the difference between these? If I'm replacing the engine, can I swap one for the other? Any way to tell what I currently have?
/ Long block vs normal Ford 4500? #2
Long block usually means complete from pan to valve cover and usually includes the front timing cover.
It likely would not include the manifolds, water pump, injector pump and lines and injectors on a diesel, or carburator and governor if a gasser.
I've never heard of a normal block.
Around here we call it a short block.
Short block would include block, crank, pistons.
It would not include the head, pan, timing cover or any other peripherals.
A crate engine would likely include everything - even the starter. Drop it into the tractor, hook up fuel lines and radiator hoses and go.
/ Long block vs normal Ford 4500? #4
They are all basically the same, the yellow engine has more applications listed for some reason. Since they are all from the same dealer, give them a call for any differences. For me, pricing and warranty would help me make up my mind. If the used engine is relatively low hours and warranted, I would prefer it.
/ Long block vs normal Ford 4500? #5
If you will be doing the re-powering and aren't very mechanic-ey , the long block might be easier for a first timer.
/ Long block vs normal Ford 4500? #6
Did you order or obtain an engine yet?
Yes. Found one in TX for a good price. Should ship in 3 weeks.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2010 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2010 DRAGON 150...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
