3-Point Hitch Long 48" Brush Hog on BX25
   / Long 48" Brush Hog on BX25 #1
bubbastarr
Currytown, NY
Kubota BX25
Anyone see any problems with this set up. Found a used brushed hog which is affordable but want to make sure it fits and will work well. I have the 3pt hitch already? Any advice is appreciated.
   / Long 48" Brush Hog on BX25 #2
From what I see it looks like it will not work at all or will do a fantastic job.
   / Long 48" Brush Hog on BX25 #3
Your tractor should be 44.5 inches wide and with almost 18 PTO HP, you'd have no problems at all with a 48" brush cutter. Just remember that they cut best when the front of the cutter is a little lower than the back.
I've been running a 48" cutter on my B6100 for years and as long as the weeds/brush aren't much higher than the hood, it does well, really well.
   / Long 48" Brush Hog on BX25 #4
I run a 48" Land Pride rotary cutter on our BX2660 and it works quite well.
   / Long 48" Brush Hog on BX25 #5
I have a squealer SQ480 on my BX25. It works fine, but can get overwhelmed and stall the tractor when it hits certain stuff I shouldn't be running over. Keep the front lower than the back and the top link loose so it follows the ground better.
   / Long 48" Brush Hog on BX25 #6
Like Triple R, I run a 48" Landpride on my BX2660. Many hours and tall weeds/trees have been leveled with this set up.
Thanks for the advice. Got it working today...After some fighting. It worked like a champ. Lot of fun too.
   / Long 48" Brush Hog on BX25 #8
just make sure the nuts holding the blades are tight the torque is high 450 lbs and the blades swing free Paul
   / Long 48" Brush Hog on BX25 #9
I am wondering if a Kubota BX25 w/42" brush hog would do well in 5"-6" grass and weeds. Thinking of buying a 42" brush hog but not if a 17HP diesel won't pull it at a reasonable pace without stalling. Never run a brush hog before, I could use some advice. Thanks!
   / Long 48" Brush Hog on BX25 #10
Go on YouTube, a guy is running a 48" cutter on a BX24. Looked like he was doing pretty good.
2005 CHEVROLET SILVERADO (A52472)
2005 CHEVROLET...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
