Long 460 45hp Mysterious oil leak.
   / Long 460 45hp Mysterious oil leak. #1
Larold
Louisville, Ky
Long 460 45HP
My long 460 45hp tractor has a steady oil leak. So I replaced the rear seal which fixed the main oil leak but I still have a steady leak coming from between the block and the bell housing half way up on the left side only when its running.
Found it. I had an "AHHAH" moment after I wrote the post. There is an oil passage with a plug (looks like a tiny freeze plug) in it on the back of the block. It had somehow gotten sideways a little which caused a pretty good leak. I was able to clean everything up and reuse the plug which no longer leakes. I can break my tractor in two including removing flywheel and bell housing in 1hr 30mins now heheh.
   / Long 460 45hp Mysterious oil leak. #3
Cool, now all you need is an extra $1250 and you can put a low gear reduction box in it (I ended up adding an Allis 160 to the "stable" just to keep from doing that (needed a much slower gear for tilling, etc)
Reduction Gear Assemblies
BTW, welcome to TBN... Steve
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
