Long 360 hydraulic filter
   / Long 360 hydraulic filter #1
shane12970
Jones Al
52 8N
New filter has rubber washer glued to one end. Does washer go toward front or back of try. Thanks
   / Long 360 hydraulic filter #2
Take a look at your accessories. On some the washer goes against a flat plate on the engine....note observe a flat plate for gasket to which the gasket can seal. Then check the mounting parts to see if there is something to seal the far end of the center rod considering old oil enters the circumference of the filter housing and exits through the holes in the center rod as clean oil. You don't want old oil leaking past the outer end of the filter and getting into the clean oil, center section of the filter.
I don't have one but did have a Ford with such and that is the basis for my answer.
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2021 TAKEUCHI TL12V2 SKID STEER (A51242)
2021 TAKEUCHI...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
UNUSED FUTURE SKID STEER QUICK ATTACH BACKHOE ARM (A51244)
UNUSED FUTURE SKID...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
