Long 360 fuel lift pump
   / Long 360 fuel lift pump #1
JB Bader
Cumming
Long 360
I ordered a replacement fuel lift pump for my long 360. The top of the upper housing has a flat metal seal. The original pump has a dome shaped cap on the upper housing. I am trying to find out if I need to install the domed cover on the replacement pump before ii install new pump.
An internal screen filter sits at the base of the domed cover. It seems to me without the domed filter the is no way for fuel to wash through the filter. The replacement pump came with a gasket that would fit at the base of the domed cover....so it seems to indicate it should be installed on the new pump.
Thank you for any input for a rookie mechanic.
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
KSI Conveyor (A53472)
BUSH HOG 3308R-2 LOT NUMBER 105 (A53084)
BUSH HOG 3308R-2...
UNUSED 2022 MASTER TOW MODEL 7 CAR DOLLY (A51247)
UNUSED 2022 MASTER...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
