Long 310 Hydraulic lift problem
/ Long 310 Hydraulic lift problem #1
bladerunner3
Hello all,
I have a recently purchased Long 310 or 260 which is a neat little tractor, overall, but has a problem with the hydraulic lift in that it will initially lift an implement, but after reaching the set position, will then lower it, lift it, lower it, lift it, etc.... You get the picture. If there is no implement attached, the lift goes up to the set position and stays there. Any ideas on what could be wrong with it??
/ Long 310 Hydraulic lift problem #2
i do not know if your joystick has a floating position. i do not know Long tractor. as far as i know,some tractor have four position in the joystick--lift,down,float,stay. when it on the float the 3 point will down and up.
/ Long 310 Hydraulic lift problem #3
I don't have any experience with a Long, but it sounds like it is "hickuping". The position control senses that the arms are lower than the setting and raises them back up. Then they leak down again, and on an on. I would think you have leakage in the control valving or the lift cylinder seal.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A61307)
2023 Top Air ATV...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2006 Nissan Murano AWD SUV (A59231)
2006 Nissan Murano...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
