Long 310 Hydraulic lift problem
   / Long 310 Hydraulic lift problem #1
bladerunner3
Hello all,
I have a recently purchased Long 310 or 260 which is a neat little tractor, overall, but has a problem with the hydraulic lift in that it will initially lift an implement, but after reaching the set position, will then lower it, lift it, lower it, lift it, etc.... You get the picture. If there is no implement attached, the lift goes up to the set position and stays there. Any ideas on what could be wrong with it??
   / Long 310 Hydraulic lift problem #2
i do not know if your joystick has a floating position. i do not know Long tractor. as far as i know,some tractor have four position in the joystick--lift,down,float,stay. when it on the float the 3 point will down and up.
   / Long 310 Hydraulic lift problem #3
I don't have any experience with a Long, but it sounds like it is "hickuping". The position control senses that the arms are lower than the setting and raises them back up. Then they leak down again, and on an on. I would think you have leakage in the control valving or the lift cylinder seal.
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
Hyster H225E (A47384)
2019 Bobcat E35I Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E35I...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
