Long 2610 sleeve interference fit specification
   / Long 2610 sleeve interference fit specification #1
bluechip
Veteran Member
Arkansas, USA
Have a long 2610 block at a machine shop getting new cylinder liners installed. the liner OD is 106mm. as are all the liners I have found for that engine. after removing the original liners, the machinist says the new ones measure .009" inteference which seems high for cast block. anyone have a long service manual that specs this fit? If not I will have to find one and wait till it comes in to get this block done. Thanks.
   / Long 2610 sleeve interference fit specification #2
https://tractorpoint.com/pdf/Long-Service-Manual-360-460-510-series.pdf
Here is a link to a manual covering (among others) the 510 . This may well be a three cylinder version of the engine used in the 2610.
There is a section in "fits and tolerances" that covers liner and block bore specs. Looks like the difference should be more like
.004 to .006 in. by what I see.
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A52128)
John Deere 752...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
John Deere A Tractor (A50514)
John Deere A...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
