rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,426
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
This is a log splitter I'm in the process of building. Would have been nice to have it for this season but I got started a little late and haven't been able to work on it as much as I would like due to work and having too many other projects going. Hopefully I'll get it done in time to still use it this season. The attached image shows the I-beam which I am using. It's a 8' 4" piece of W8 24 that I got as a drop from a fab shop where a friend used to work. The cylinder is an 4" x 24" Eaton Fieldmate that I picked up from Surplus Center (would have like a bigger cylinder but it was cost prohibitive), the hoses came from TSC. On the end of the beam you can where I welded in some 8" x 6" x 1/4" plate to reinforce the part of the beam that's under the wedge, which makes it 3/4" thick, the same thickness as the wedge.
