logsplitter lift
/ logsplitter lift #21
I purchased a speeco 28 ton a couple months ago and have been adding a hydraulic lift as time allows, I had to add a new hydraulic control valve to operate the main cylinder and a lift cylinder that I purchased from surplus center. Here's a few pics.
Added a battery box for the 11hp honda electric start that replaced the briggs that came with the splitter.
Still need to finish up paint and hydraulic hose.
/ logsplitter lift #23
BethelHntr,
Nice work :thumbsup:
/ logsplitter lift #24
Very nice.
Do you have any plans for a "foot" to keep it from tipping if you get a heavy round on there?
Aaron Z
I'm not sure this will be the first time I've ever used one, Do you think I'll need one?
/ logsplitter lift #26
/ logsplitter lift #28
Hey @BeltheHntr how did your log lift turn out? I'm thinking of making one for my Oregon which is a similar design. I think it uses the same beam, just larger wheels.
/ logsplitter lift #29
I have a lift on mine. It’s a major back saver.
/ logsplitter lift #30
I would love to have a lift. But most of my splitting is 20" or less, but even those get heavy. I had been using my loader to get them at the right height. Then I would just pick them up and set them down. No lifting from the ground, but even that was getting to be too much.
My solution is an 8' 4x4. I set on end on the lower web of the I-beam on my splitter. Then I just roll the piece up the inclined plane. It is slow, but it saves my back. I wish I would have thought of this years ago.
I also hate splitting in the vertical position. I still need to make a platform similar to what was shown in the video
Doug in SW IA
/ logsplitter lift #31
All my rounds lately are in the 30" range. Use the splitter vertical and tractor to move close. But it's still a bear to get in to the bar for a clean split.
Maybe something like your 4x4, but with 4x1 and drop off from FEL onto these and slide to splitter would work.
/ logsplitter lift #32
I built this maybe 35 years ago and plan to restore it one day, I don't burn wood anymore so no hurry. it has about 75 feet of cable so dragging big rounds or even a 10 log to the splitter was no problem. If a round was big enough I would use the lift to sit it on the beam and then hook the tongs on the half that I wanted to fall away so it was ready to sit back up. Oh and the swivel is the front hub off a Lincoln continental, I guess during restoration I'll grease the bearings. :)
/ logsplitter lift #33
Don't need one myself, since 90% of my wood is from hedgelaying, so max 6-8" dia, but the best solution I've seen is from NZ :-
He's a very clever bloke, that one!
/ logsplitter lift #34
I had a Didier splitter when we burned firewood. Some of my ancient Ponderosa pines were - 32" to 36" on the butt.
Alternate to log lift. With the FEL & bucket - dig a shallow "hole". Roll the splitter rear tires into this hole. Now the splitter is at about the same level as the surrounding ground.
Just a matter of rolling the round onto the splitter rail.
A whole lot easier getting the round up on the rail when the rail is sitting on the ground.
/ logsplitter lift #35
If I was still running a splitter I would do something similar to how Sawyer Rob processes. Look for some of his posts. I had planned to do something similar until I decided a wood processor was a better option for me.
He cuts the rounds onto a trailer and then rolls them off the trailer to his splitter...no lifting.. His splitter has a fixed wedge and he can push the splits off the table without having to pick them off the ground.
Log lifts can be slow and that makes SR's method more attractive to me. it is fast and easy to roll rounds from the trailer to the splitter.
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
JMR TREE BOOM (A61572)
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
