Logsplitter Detent Valve Leaking
   / Logsplitter Detent Valve Leaking #1
marimus
Toogoolawah, Queensland, Australia
New Holland TT75
Hi guys,
please excuse my misuse of terms that i'm sure follows. I'm not well versed in hydraulics speak :laughing:
Anyway, I have a 3PT logsplitter that runs off my tractor. It has started leaking out the end of the hydraulic spool, and the leak is getting worse. Its now a constant drip.
I am having trouble taking the valve apart though, i've never disasembled one with a detent.
There is a circlip at the bottom end holding a round plate in place, I figured after removing this the spool would just slide out (like it does on my tractor controls) but it seems held in there by a spring? :confused:
Any tips on getting it appart, or anybody have an exploded view picture of a basic logsplitter valve?
   / Logsplitter Detent Valve Leaking #2
My splitter valve was hanging up, and the spool was being held pretty snug by a torn-up 0-ring. A close-up pic of yours might help decipher what needs to be done.
On some, the detent is a spring-loaded ball (like a roller bearing ball) that is behind a set screw. Might also be a spring on the spool that adjusts the relief pressure setting.
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2017 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 DRAGON 130...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
90007 (A51694)
90007 (A51694)
