Log tongs
   / Log tongs #1
bobodu
Platinum Member
Whitley County,In.EIEIO
Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
Made these today...
Just some 3/4" X 3/8" flat stock heated up in the wood stove and bent into a hook. Then,I backed that with another piece of flat stock to make a "T" cross section. Some 1/2" pieces of stainless round rod make up the teeth.
   / Log tongs #2
Heating in a wood stove is a practical idea. Lots cheaper than oxy-acetylene!
That's using your head - and stove. Blacksmithery is a handy knowledge.
   / Log tongs #3
very nice, we've got a few sets of these, that we got cheap off the forestry commision or another big company because they were getting rid of old equipment
   / Log tongs #4
I recently made a cant hook for no cost. Catalog prices are $70 or better. If you can make it or find it nearly free thats best. I used to have a small sawmill and used skidding tongs to drag up all the logs to the cold deck.
   / Log tongs
Built my first forge when I was about 14 at the tail end of the steam locomotive era. Back then,it was real handy to walk down the tracks a half mile and pick up all the free coke I could carry. Now days,it's just a pain in the butt to even find coal around here. It can be had but it's not really worth my trouble. Thought about a gas forge....but it lacks the "magic" of a good fire. I use my O/A torch on some small stuff and my weed burner on the larger bits. But as anyone who heats a shop with wood knows,you seem to spend a lot of time poking the fire whether it needs it or not!! Might as well heat some steel...
Here's a shot of my stove..the firebox is a 60 gallon compressor tank and I have a furnace blower behind the heat exchanger. I have since insulated the walls and covered them with tin from a feeder bunk roof.
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
8' DISC HARROW (A51247)
8' DISC HARROW...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
COFFING JLC / TON ELECTRIC HOIST (A51248)
COFFING JLC / TON...
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
