Log Splitter Won't Split
   / Log Splitter Won't Split #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I recently got a log splitter from a buddy that hadn't been used for 5+ years and sat outside. It is a 13-ton MTD "Split-it". Model number: 240-610-000.
With a new air filter and spark plug, as well as fresh oil, the Briggs fired to life and purrs like a kitten.
I threw a log on the beam and the ram extended and stopped, touching the log. That's it. That's all she wrote.
I put the valve in "retract" and it clicked into the detent. It did NOT automatically click out when the cylinder was fully retracted.
I checked the hydraulic "oil". It was MILK-Y! Clearly water had gotten in there during storage. I don't know what I was thinking not changing this from the start.
I drained the oil and am debating what to do next. I need a $6 gasket (#36 in this diagram: Diagrams).
I don't want to dump $30 worth of oil and $10 more into parts just to find out the pump or cylinder is bad.
Could the milky oil have caused my problems?
ac
   / Log Splitter Won't Split #4
Well, you might consider adding one.
Definitely! If I can get it working without too much money. This is a 2nd splitter for me so I really don't want to spend more than ~$100 getting it back online. If it costs much more than that I will just throw it on craigslist and make it someone else's trouble.
ac
   / Log Splitter Won't Split #6
This is the time to put a pressure gauge on it and see if the pump is ok.
   / Log Splitter Won't Split #7
Yup check pressure and put a new valve on, that should do it.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
