Log Splitter Won't Split
/ Log Splitter Won't Split #1
avc8130
Northern, NJ
Kubota L45
I recently got a log splitter from a buddy that hadn't been used for 5+ years and sat outside. It is a 13-ton MTD "Split-it". Model number: 240-610-000.
With a new air filter and spark plug, as well as fresh oil, the Briggs fired to life and purrs like a kitten.
I threw a log on the beam and the ram extended and stopped, touching the log. That's it. That's all she wrote.
I put the valve in "retract" and it clicked into the detent. It did NOT automatically click out when the cylinder was fully retracted.
I checked the hydraulic "oil". It was MILK-Y! Clearly water had gotten in there during storage. I don't know what I was thinking not changing this from the start.
I drained the oil and am debating what to do next. I need a $6 gasket (#36 in this diagram: Diagrams).
I don't want to dump $30 worth of oil and $10 more into parts just to find out the pump or cylinder is bad.
Could the milky oil have caused my problems?
ac
/ Log Splitter Won't Split #4
Well, you might consider adding one.
Definitely! If I can get it working without too much money. This is a 2nd splitter for me so I really don't want to spend more than ~$100 getting it back online. If it costs much more than that I will just throw it on craigslist and make it someone else's trouble.
ac
/ Log Splitter Won't Split #6
This is the time to put a pressure gauge on it and see if the pump is ok.
F-250 SuperDuty (A63689)
F-250 SuperDuty...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
