Backhoe Log splitter vs. aux. hydraulic hookup on Yanmar LX4900
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #1
manysek
middle of nowhere, NY
Yanmar LX4900
:anyone:I am new to this so is my tractor. I plan on purchasing a hydraulically operated 3p log splitter but was unable to determine if I can simply disconnect the hoses from my backhoe and hook them directly to the log splitter which seems to have a 3-way valve that completes the circuit when idle. Splitter technical description says that I need auxiliary hydraulic outputs but don't I have them already? The tech support of the splitter vendor was not knowledgeable enough to clarify that. Tractor dealer doesn't have definite answer either unless I use implements approved by them, right? I appreciate your help in this matter.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #2
Post a picof the back of the tractor where the BG hoses attach
Jim
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #3
Backhoe has QD lines? You simply need a "goesinta" and a "goesoutta" line that is live. Bungie the respective BH lever and you are good to go.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #4
I'd rethink the 3pt splitter. I know it seems logical. But unless you have at least 11gpm output it will be real slow. And then you can't use the tractor for anything else, like hauling logs or the split wood. The small engine ones cost more but are more versatile. I tow mine into the woods with a quad and use a quad with landscape trailer to haul the split wood.
And when I say slow, I mean really slow. My buddy has a Kubota L3010 30 hp with the TSC splitter and it's glacial slow compared to my Northern Tool tow-behind with 5.5 hp Honda 11 gpm pump.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #5
Exactly what I found when I did have a 3pt splitter and tried to run it off the tractor hydraulics. Slow, and it ties up the tractor. So I used it as the basis for a stand alone splitter, adding an 8hp engine, a 16gpm two stage pump (another thing tractors don't have), wheels, hitch, etc, and have been much happier with the setup than when it was tied to the tractor.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #6
I'd like to see pics as well. I'm very familiar with the rear remotes on the LX series but unfortunately didn't pay any attention to the CB85 backhoe hookups when I've been near them.
I also split wood and use the LX bucket to bring fresh cut rounds to a 5hp gas splitter. The loader is great for lifting the rounds to waist height so you don't have to stoop over to pick them up. I can see a 3-pt splitter handy if its the type that can split oversized rounds on the ground vertically, my gas splitter does not have that ability.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #7
I don't think you will need to bungee cord anything. The backhoe port should be continuous flow.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #8
Generally, the backhoes are run by a power beyond type circuit. Do you have to plug the in and out line for the BH into each other when it's disconnected?
Your 3pt splitter will only be slow if you don't take the time to match the cylinder size on the splitter to the GPM output of the machine.
For example, if you buy a splitter attachment with a 5" cylinder it's gonna be slow unless you have about 20 GPM.
My tractor has only 5GPM output so I got a splitter with a 3.5" cylinder. The cycle time from on end to the other is 7 seconds with the throttle just love idle.
The splitter is rated at 13 tons using 3000 PSI, my machine only has about 2400 PSI so I think I have about 10 ton capacity. It's rare for me to run into a log I can't split. There are upsides and downsides to 3pts and stand alone... stand alone have an additional engine to maintain. 3pts can be a bit slower and tie up the tractor...
Regards,
Chris
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #9
The op's LX4900 should do just under 9 GPM of hydraulic flow at the rated 2600rpm.
   / Log splitter vs. aux. hydraulic hookup on Yanmar LX4900 #10
I don't know why you'd want to burn up hours on your tractor running a log splitter? You're consuming expensive oil changes, filters, and depreciation for want of a $300 pump and gas engine.
If you want to keep the splitter you have, I'd consider looking into making a little power pack for it.
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
1985 Chevy C8500 Auger/Derrick Truck (A50323)
1985 Chevy C8500...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
