Log splitter question
/ Log splitter question
Hi Clyde, when you say the vent cap was lower than the rest of the system, what does that mean? Lower than the pump, lower than the cylinder? I'm curious because when I replace my reservoir, I want to make sure I mount it in the right place.
Thanks,
Chuck
joetrausch, this was a home made unit so they probably used whatever was available. The 18HP is actually the front end of an old Craftsman lawn tractor. Looks kind of strange sitting atop a log splitter. The head lights still work so you can split wood in the dark if you want /forums/images/graemlins/smile.gif I'll try to get the pump info ASAP so I can figure out what size tank to get/make.
As for the RPM's I have no idea. I'm not even sure what would be an easy way to figure that out. In fact, when I first got this thing I wondered if I should run it full, 1/2, or 3/4 throttle. I just found a speed that I could keep up with and went with it. Hopefully I didn't run it too fast and hurt the pump.
Thanks again for the help!
Chuck
/ Log splitter question #23
My unit is I think what they call towable or self contained. It has two wheels and a hitch. The reservoir itself is actually the base for the axles. It helps make for a low gravity center. Yes, the vent/filler cap is lower than the pump, cylinder, engine, or control valve. The filler cap is located on the outermost end near one of the tires. It probably would have been better if the manufacturer would have placed it closer to the center of the reservoir near the main "I" beam.
/ Log splitter question #24
My splitter (home-made) has a 6 hp engine, a commercial 2-stage pump and auto-centering 4-way valve. It has a 1.5 gallon reservoir and works great. The small reservoir works because the return line from the 4-way valve goes straight to the inlet side of the pump, with a tee in the line, and the reservoir mounted above the tee. This way the only flow into and out of the reservoir is the net displacement of the cylinder rod - only about 20% of the total flow. On the return stroke the extra oil goes into the reservoir, on the extend stroke the extra is pulled from the reservoir. I don't know why more splitters are not made this way. There is very little hydraulic line loss because the return piping from the valve to pump can be large and short. The small flow in and out of the reservoir spreads out the heat evenly. There is less plumbing, the unit is neat and compact, and has worked like a charm for many years.
BTW, you can figure the output of your pump by measuring the size of the cylinder and the no-load stroke time. For example, 4" diameter is a common cylinder size. A 24" extend-stroke would use 1.3 gallons. If the stroke took 10 seconds, flow would be 6 x 1.3 or about 8 gpm.
If your pump is 2-stage, it senses back-pressure and directs the oil into its smaller 2nd-stage chamber which puts out more pressure but less volume. (just what you want when the splitting head starts into the log) When splitting pressure drops, flow is directed to the higher-volume stage to speed up the ram. Usually engine rpm will drop a bit during the changeover to the high-pressure chamber, but the governor should restore it right away.
As always, prompt cheerful refund if info is bogus or irrelevant. Take care, Dick B
/ Log splitter question #25
Here are some pictures of my home made log splitter. The ones that follow will be of a cooler I installed because it would run too hot after a while - especially in the Texas summer heat.
It's a 13hp, 22GPM two stage, 11 Gal tank, 5x30 cylinder, just over 12 seconds of round trip travel time out and back.
/ Log splitter question #26
The tank has a thermometer mounted in it so I can keep an eye on the temperature. Hydraulic oil runs pretty good at 120 to 130 degrees. The grey box on the left is a thermostat that constrols the cooling fan when the switch is set for automatic.
/ Log splitter question #27
The cooling coil is made for hydraulic applications and its ratings are matched to the pressure and flow of my pump.
/ Log splitter question #28
The cooling fan is a 12VDC fan that is made for hot rods. It draws only a few amps so the altenator keeps up with it. It's controled by the thermostat mounted in the tank. I can adjust the temperature setting for when it comes on and goes off. I also have a three position switch so I can turn the fan on/off manually or leave it in auto mode.
/ Log splitter question #29
Here you can see the switch. The guard in front of the fan keeps stray logs at bay.
/ Log splitter question #30
Here's an older picture of the log splitter when I first finished it. That's a 36" piece of Texas post oak on it. The hydraulic side lift was a must for that one.
I've got about 120 hours on it now and it's about 9 or 10 years old.
Wow Gary, that is one nice splitter! I'm thinking of taking a welding class sometime in the near future, maybe I'll be able to make something like that someday. I'll have to start from scratch, cause my splitter will never look like that /forums/images/graemlins/smile.gif Thanks for the pictures and the info.
Chuck
/ Log splitter question #32
Beautiful product - truely professional !
/ Log splitter question #33
Real nice work, Gary. Clean, simple, compact, and a BIG cylinder. With a 12 second cycle time you need the 22 gpm pump, I bet sometimes you wish it was bigger! You obviously thought through your design and layout real well. What would you do different if you built a new one for yourself? Jim
/ Log splitter question #34
That is a really nice piece of work. I think I like the pin striping best of all.
/ Log splitter question #35
Most home-made splitters are way overdesigned - which is to say they aren't really designed at all. They are an accumulation of available parts where the usual selection rule is "bigger is better".
But bigger is not always better. Bigger may be just heavier, hotter, and more trouble to move. A 4" cylinder runing at 2000 psi makes 25,000 pounds of force. If that isn't enough, your wedge is too blunt. A 5" cylinder is 50% more in every way - more output force, but needs more gpm to keep the speed up.
The main source of heat in a splitter is the viscous friction of shoving all that oil through all those fittings - even when there is no splitting going on. The answer is lower flow and using components better matched to the job. My 2 cents.
OK, finally got a few pictures this morning, but still don't have the model number, etc. from the pump yet. I couldn't read it, need to spray it off a bit and get some light on it. But at least these pictures will help give you an idea of what I have to work with /forums/images/graemlins/smile.gif
This is a front shot, don't ask me why the guy mounted a tractor seat on this thing!! He said something about his wife sitting there and working the controls /forums/images/graemlins/smile.gif She must have some long arms!
Here is the little hydraulic reservoir I was talking about. Looks like it would hold a couple of gallons max.
One more of the tank....
One of the ram and controls...
The pump... still need to get the numbers off it to figure out GPM.
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2007 VOLVO VHD QUAD/A VACUUM TRUCK (A67148)
2007 VOLVO VHD...
1997 International 3800 School Bus (A64194)
1997 International...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
